Poll
How many ICs did you used yourself, in your own projects (not at work), in 2019
0
0 (0%)
less than 10
3 (12%)
10-100
13 (52%)
100+
8 (32%)
What is an IC?
1 (4%)
Total Members Voted: 25
Author Topic: How many integrated circuits do you "consume" yearly?  (Read 1178 times)
Offline RoGeorgeTopic starter
« on: January 06, 2020, 10:52:55 pm »
Was doing some parts inventory combined with new year's resolutions  ;D , and thinking about how many ICs one uses in a year for personal projects only.  Not counting here production units or anything made for sale, also not counting ready made devboards or modules that are bought assambled, but counting, for example, the ones you bought as a kit and assembled yourself.
1. From Op-Amps to FPGAs, everything goes, doesn't matter analog or digital or whatever, for example, roughly, how many ICs do you used in projects during 2019?
2. Do you prefer to keep stock, or order each time something is necessary?
Offline magic
Re: How many integrated circuits do you "consume" yearly?
« Reply #1 on: January 06, 2020, 11:43:30 pm »
I don't build much stuff so probably <10 last year. For circuits which I don't intend to use often I also try to minimize their storage footprint and reuse ICs (in one instance even a power transistor) by only mounting sockets on the board. So there is a box with half-empty boards and there is a box with ICs and only a few of each :)
Offline piguy101
« Reply #2 on: January 07, 2020, 04:25:48 pm »
Probably 100 or so each year. I like to make at least 2 of every board so I always have an immediate backup replacement when things go wrong or a scope probe slips and shorts something.
But how many ICs do I buy each year? :-DD That's a different story.
Offline tom66
« Reply #3 on: January 08, 2020, 09:12:37 am »
10-100, but most ICs I would use are simple (a dual MOSFET is, strictly speaking, an IC).  A few FPGAs that have a higher BOM value than most things put together though.
Offline magic
« Reply #4 on: January 08, 2020, 09:20:44 am »
A dual transistor is, strictly speaking, an IC only if it's fabbed on one die :P
Most are just two dies in one piece of plastic. They may promise "near" locations on the wafer, if you are lucky.
Offline tom66
« Reply #5 on: January 08, 2020, 09:40:48 am »
It's a circuit integrated into a single package; doesn't matter how many dies there are ;).
I use EZR32 processors at work, they consist of an EFM32 plus a Si446x radio in the same package, but as discrete dies. Still an IC, although it contains two dies in one package.
