err so why tell the world. isn't this like the allies telling the germans that enigma had been cracked practically as it went into use ?
I don't know a lot about lasers but what if the missile is reflective, won't the beam just bounce off ? I would have thought a faster destroyer missile would have made a better job of it
No material is 100% reflective, though it has long been known that such coatings would increase the time to kill by an order of magnitude.
The problem with shooting a missile with another missile is delivery. Any smallish missile easily deployable from existing ship and air systems doesn't have the range to hit a ballistic missile beyond either the initial launch phase or the terminal reentry phase. This system does already exist and IIRC is currently fielded, but it's really not much more than a modified Standard Missile coupled with an Aegis radar system. Of course it really ends up just being a terminal phase defense unless you somehow manage to get close to the launch site. This would probably work for North Korea and there is absolutely no doubt that it's solution they are using. But it won't work for Iran or (most of) China, or Russia. Supposedly we're not building it to defend against them, and that basically seems true.
Wartex mentioned decoys and that is exactly what the ABL is designed to counter. The idea is that you can fly this airplane higher, and closer to the missile during the initial launch phase. At this time, the common decoys aren't really effective, especially since the target is visually tracked (and it by definition must always be since you're shooting light at the target
The other option is the midcourse interception, but the technical problems are huge. You fight a ballistic missile at another ballistic missile, but now you have to track the target accurately at huge ranges. The radar becomes a large limiting factor and makes it really (really) expensive.
Ballistic missile defense is far from a solved problem and if it isn't technical problems it's practical problems. Luckily the North Koreans are a bunch of idiots (go figure) and they're the only belligerent ones at the moment. Other near term problem children like Iran only have simple launch systems so even simple terminal phase defense systems can easily defeat them. Hopefully long term problem children like Russia and China are growing up too fast to consider the use of ballistic missiles to be serious bargaining chips.
