Have you used Altium for doing some projects from beginning to end, if you did you will never come back to eagle
Eagle it's not on same level it's useful but it's a toy a little better than Proteus that is even easier to work than eagle but still a toy
Kicad is a better option than eagle that is also expensive
In the past I have used Multisim and Ultiboard for a couple of years. It was terrible. I don't know if it has improved in the mean time.
I have used altium designer for exactly a year. I have done several projects with it. One of my (ex) colleagues was very proficient with it.
Although it wasn't too bad, we experienced several issues with it. It was slow, in case of internet connection faillure, we got
annoying popup messages about the license. Sometimes we couldn't use it because it thought we had too many seats in use.
Many times we had to call support. At least ones a day I had to restart because of instabilities. Probably because altium is still
stuck in the 90's using an antique language & compiler. It forces you to use windows. Difficult to use git, "git diff" is useless. Etc, etc.
Then I started to use Zukens' Cadstar. I didn't like it either. No real integration between schematic capture and board layout.
No realtime forward backward annotation. Insufficient documentation, no forum or cummunity.
Then I started to use Eagle. It's not perfect either but after a learning curve, I was able to do the job faster and more efficient.
It doesn't use the stupid "select an object, then select a tool" method. Eagle uses the much more efficient approach of
"select a tool, then select an object" method. Eagle saves the data in an open, human readible format that works nicely with git.
And it doesn't force you to use windows. Startup time of Eagle and memory usage is superior.
Eagle can work nicely together with other software or, if you wish, you can write your own extensions and customize it.
