Author Topic: KiDOOM - DOOM in KiCad, plus ScopeDOOM on a scope  (Read 623 times)
Offline AxlesTopic starter
« on: November 26, 2025, 08:40:32 pm »
Hi All,
I got DOOM running in KiCad by rendering it with PCB traces and footprints instead of pixels.
Walls are rendered as PCB_TRACK traces, and entities (enemies, items, player) are actual component footprints - SOT-23 for small items, SOIC-8 for decorations, QFP-64 for enemies and the player.
How I did it:
Started by patching DOOM's source code to extract vector data directly from the engine. Instead of trying to render 64,000 pixels (which would be impossibly slow), I grab the geometry DOOM already calculates internally - the drawsegs[] array for walls and vissprites[] for entities.
Added a field to the vissprite_t structure to capture entity types (MT_SHOTGUY, MT_PLAYER, etc.) during R_ProjectSprite(). This lets me map 150+ entity types to appropriate footprint categories.
The DOOM engine sends this vector data over a Unix socket to a Python plugin running in KiCad. The plugin pre-allocates pools of traces and footprints at startup, then just updates their positions each frame instead of creating/destroying objects. Calls pcbnew.Refresh() to update the display.
Runs at 10-25 FPS depending on hardware. The bottleneck is KiCad's refresh, not DOOM or the data transfer.
Also renders to an SDL window (for actual gameplay) and a Python wireframe window (for debugging), so you get three views running simultaneously.
Follow-up: ScopeDoom
After getting the wireframe renderer working, I wanted to push it somewhere more physical. Oscilloscopes in X-Y mode are vector displays - feed X coordinates to one channel, Y to the other. I didn't have a function generator, so I used my MacBook's headphone jack instead.
The sound card is just a dual-channel DAC at 44.1kHz. Wired 3.5mm jack → 1kΩ resistors → scope CH1 (X) and CH2 (Y). Reused the same vector extraction from KiDoom, but the Python script converts coordinates to ±1V range and streams them as audio samples.
Each wall becomes a wireframe box, the scope traces along each line. With ~7,000 points per frame at 44.1kHz, refresh rate is about 6 Hz - slow enough to be a slideshow, but level geometry is clearly recognizable. A 96kHz audio interface or analog scope would improve it significantly (digital scopes do sample-and-hold instead of continuous beam tracing).
Links:
KiDoom GitHub: https://github.com/MichaelAyles/KiDoom, writeup: https://www.mikeayles.com/#kidoom
ScopeDoom GitHub: https://github.com/MichaelAyles/ScopeDoom, writeup: https://www.mikeayles.com/#scopedoom
The following users thanked this post: thm_w, Kean, xvr
Online Benta
Re: KiDOOM - DOOM in KiCad, plus ScopeDOOM on a scope
« Reply #1 on: November 26, 2025, 11:17:50 pm »
There's a life out there. Try it.
« Last Edit: November 26, 2025, 11:28:48 pm by Benta »
Offline Psi
« Reply #2 on: November 26, 2025, 11:29:47 pm »
Get a life.
Stop attacking new members.
People gain a lot of skills and experiences pulling things apart and putting them back together like this.
The following users thanked this post: Axles, thm_w, Kean
Online SteveThackery
  • 50 year novice
« Reply #3 on: November 26, 2025, 11:33:52 pm »
Hi All,
Very impressive! And I bet you learned loads on the way.
The following users thanked this post: Psi, Axles
