Author Topic: Largest Value of Resistance Ever Measured?  (Read 26823 times)
Offline xrunnerTopic starter
  • hp>Agilent>Keysight>???
« on: June 24, 2013, 11:31:17 pm »
Reading this thread here on the forum where the Transmille's 8081 Precision DMM is shown in a video, I thought of a question -
I hope Dave gets one of this for next teardown :-)
It can apparently measure resistance into the Terraohm range.
What is the largest value of resistance ever accuratley measured and how was it done?
Offline c4757p
  • adieu
Re: Largest Value of Resistance Ever Measured?
« Reply #1 on: June 24, 2013, 11:45:02 pm »
These resistance standards go to 10 petaohm, so I'm sure the largest ever measured is insanely high...
« Reply #2 on: June 24, 2013, 11:49:52 pm »
Day-um.
At least you don't have to worry about the res. of the contacts when making those. I'd love to see what's inside that box. What substance does the actual resistance consist of that allows you to make petaohn values.
Offline c4757p
  • adieu
« Reply #3 on: June 24, 2013, 11:53:12 pm »
I'll take contact resistance any day over what you do need to worry about to measure those!
Offline dr.diesel
« Reply #4 on: June 24, 2013, 11:53:42 pm »
Mmmmm, what industry would purchase a 10petaohm standard?
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #5 on: June 24, 2013, 11:54:20 pm »
So at the maximum specced voltage of 1Kv, current is 0.1pA  , which I make about 60,000 electrons per second.
I suspect noise might be an issue - I expect you'd need to measure over a pretty long period.
Day Job: Mostly LEDs
Offline c4757p
  • adieu
« Reply #6 on: June 24, 2013, 11:55:17 pm »
My suspicion? They're purchased to calibrate resistance meters, which are used to make the resistors, which are used to calibrate resistance meters, which are used to make the resistors...  :scared:
« Reply #7 on: June 24, 2013, 11:57:29 pm »
Slow down ...
Offline dr.diesel
« Reply #8 on: June 24, 2013, 11:57:40 pm »
Ha, apparently to cal 10petaohm standards and 8081 DMMs!
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #9 on: June 25, 2013, 12:15:51 am »
i measured infinity, so whats the big deal?
The Ultimatum of False Logic... http://www.soasystem.com/false_logic.jpg
« Reply #10 on: June 25, 2013, 12:17:34 am »
Infinite resistance or are you going off-topic ...  :wtf:
Offline c4757p
  • adieu
« Reply #11 on: June 25, 2013, 12:18:18 am »
Sure, but for all we know you only measured it +/- 10000%...
Offline c4757p
  • adieu
« Reply #12 on: June 25, 2013, 12:19:44 am »
His sense of humor is almost as bad as mine.
Offline ftransform
« Reply #13 on: June 25, 2013, 01:42:40 am »
I would assume the petaohm resistors are pieces of plastic thats not teflon.
Offline phatcenter77
« Reply #14 on: June 25, 2013, 03:48:32 am »
OL?
I see it every time my meter switches to ohms...  :-DD
alm
  • Guest
« Reply #15 on: June 25, 2013, 10:37:28 am »
0.1 pA isn't that extreme, 'standard' Keithley electrometers will go down to the fA with aA resolution. Of course guarding and leakage are going to be an issue, you will need custom test fixtures to measure this. Some of them will go up to 10 POhm. This is high, but still achievable with commercial equipment. You're not up to the experimental physicist level yet, which I'm sure goes even higher.
Offline amyk
« Reply #16 on: June 25, 2013, 11:20:57 am »
I haven't found any equipment that claims to go to exaohms yet...
alm
  • Guest
« Reply #17 on: June 25, 2013, 11:35:31 am »
You won't find it in commercial equipment. Only the popular and 'easy' stuff gets commercialized, but the same and more has usually be done in the lab (either R&D or academic) first. For example, this publication from 1931 (behind a paywall) already describes a method to measure resistors up to 0.1 EOhm. I'm sure there have been further developments since then.
Offline olsenn
« Reply #18 on: June 25, 2013, 11:52:04 am »
Petaohms? Why??????????? That's just an open circuit!
« Reply #19 on: June 25, 2013, 12:06:31 pm »
Still ... I'm interested in the question I posed. What's the highest value of resistance ever actually, accurately, measured by any sort of set-up? Is it a Guinness world record? Has it been done in a lab somewhere?
Offline Stonent
« Reply #20 on: June 25, 2013, 02:34:09 pm »
The largest resistance ever to be measured by mankind will be the day my wife tells me I'm about the age to need a colonoscopy
Offline ftransform
« Reply #21 on: June 25, 2013, 02:39:40 pm »
How many ohms is a vacuum gap?
Offline bitwelder
« Reply #22 on: June 25, 2013, 04:31:40 pm »
Well, Dave recently got a petaohmmeter :D in 'EEVblog #455 - Auction Bonanza' (check from 11:00)
I'd be really curious to watch how to measure with such an instrument, i.e. avoid all the disturbances that may affect the reading of such extreme resistance values.
« Reply #23 on: June 25, 2013, 04:38:02 pm »
Well, R = E/I, so you'd have to tell me what current you measured across the gap before I can tell you how many ohms it is. Remember. if even a single electron (-1.602 x 10-19 C) gets across the gap it's a valid current, albeit very tiny. Can you assure us that not even the charge of a single electron gets across the gap? How are you sure this doesn't happen ftransform?
Offline c4757p
  • adieu
« Reply #24 on: June 25, 2013, 04:47:17 pm »
I spent almost an hour digging around for an article, but my Google-fu left much to be desired. I saw a paper a few months ago (granted, I think it was much older than that) measuring the resistance of an air (not vacuum) gap. Spoiler alert: it was very high.
Considering that conductance through a vacuum is likely to be due mostly to thermionic emission, there's going to be a very strong dependence on temperature for that one. I wonder if you could get a back-of-the-envelope calculation of the resistance of vacuum at room temperature by extrapolating a filament current vs. plate current curve for a vacuum diode.
