For a PC upgrade I bought some SATA cables for slimline optical drives, which have a different SATA+power connector compared to hard disks.
They arrived from China, and the 5V power connector needs to be cut off and replaced with a 4-pin plug to fit the floppy drive power cable in the machine. I didn't want to hack anything in the PC, so this cable gets cut.
No problem, just solder the wires to the 0.1" header pins, right?
Except... the strands of wire in the red and black leads of these, ABSOLUTELY refuses to wet with solder. I even tried a flux pen, that can pretty much make anything solder well. Also makes for very sick lungs if you breathe the fumes, as I found out one time.
In the end I had to crimp lug real wire to it, so I could attach the improvised connector.
I captured a video using the little endoscope, of a strand of this stuff just shrugging off rosin-cored soldering attempts, and staying shiny clean. But it's 272MB, and I don't know how to edit+upload to youtube.
Pic 5 below is that wire strand, still clean after multiple times sitting in a blob of molten solder and flux on the iron tip.
Whatever this wire is, it's highly solder-phobic.
I'm starting to suspect it is actually finely stranded stainless steel. Would that _really_ be cheaper than copper, by enough to make it worthwhile to substitute?
Can anyone suggest a quick way to see if it really is stainless? It's non-magnetic, so far as I can tell.
