Author Topic: Lissajou - possible with ???  (Read 8422 times)
Offline TrabanTTopic starter
« on: November 03, 2014, 08:30:57 pm »
hi guys,
I just started messing with oscilloscopes and the Lissajous patterns ... got it to work for like 2 hours, then my PM3231 broke,,,
this is what I came up with
now I am hooked and want to know ... which OSC is good for these patterns?
will 2 axis be enough if you can phase shift them ... how does one know that without reading every manual?
thanks for all info!
Offline atferrari
  • Country: ar
Re: Lissajou - possible with ???
« Reply #1 on: November 03, 2014, 10:11:20 pm »
hi guys,
Anyone that works?
Agustín Tomás
In theory, there is no difference between theory and practice. In practice, however, there is.
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #2 on: November 03, 2014, 10:17:59 pm »
Try other waveforms - not just triangle and modulated.
Also play with external triggering with a divider connected to your oscillators.
The patterns will stand still (or not), and offer a million more visual variations.
Welcome to the seventies.
Don't ask a question if you aren't willing to listen to the answer.
« Reply #3 on: November 03, 2014, 10:25:18 pm »
thanks for your answer SL4P ---
i dont know if you are familiar with Elektron Analog 4 ... it has several wave forms. ... also today, just before my OSZ killed itself , I was using the Monomachine also a Elektron Toy, it has a wavetable with sooo many waveforms...hmmm...
your idea with the external triggering is great... i didnt know it could be used in such a way...
.... what exactly do you mean by "dividers" ? would you please elaborate...
and now to my most sincere question:
except for "it must have X Y mode" how do I recognize a good Scope which will not let me down ? Could you provide me with a specific model, preferably few models?   =?  that would be really helpful
should I go for analog (or would digital also do it)
big thanks for all info!!!
Offline German_EE
« Reply #4 on: November 03, 2014, 10:31:19 pm »
The seventies would be just about right, that was when I discovered an old Heathkit scope in the Physics lab at school (and the rest is history). What you are looking at is the phase difference between the signals on the X and Y plates of the scope so here are some more things you can try:
1) Different combinations of waveform, two square waves will for example trace out the sides of a square on the screen as they interact. Sawtooth waveforms don't work too well though because then you just have a conventional scope  :)
2) Comparing two frequencies. If the two frequencies have a harmonic relationship then the pattern will be still and this is a great way of comparing frequency differences. If your pattern rotates once a second then you have a 1Hz difference between your two signals.
3) Phasing effects in music show up really well if you feed the left channel into the X input and the right channel into the Y input.
4) Finally, the advanced stuff.   O0
Warren Buffett
« Reply #5 on: November 03, 2014, 10:45:43 pm »
hey, thanks for answer ....
1) more frequencies the better... was in my first 2 hours.... will keep it in mind!
2)will get into the math part maybe in a few weeks or month ...
3)yeah the X and Y thing is the key to trippy shit!
4)i dont really like the idea of prefabricated waves... I like the rough original view... thanks for the video however!
another question;
would Tektronix Type 502A work good?
are you from around berlin?
Offline AG6QR
    • AG6QR Blog
« Reply #6 on: November 03, 2014, 11:29:03 pm »
This is one area where analog works better than digital.  Virtually any analog scope with an X-Y mode will do a fine job.  Many digital scopes don't do nearly as well.
An analog scope keeps the beam turned on continuously.  A digital scope samples for a while, then transfers its samples into video memory.  It has some "blind time" between sampling.  The extent of this issue varies from one scope to another, but it's pretty awful on entry-level digital scopes like the Rigol DS1052E.  And it's not great even on some scopes that are considerably better than that entry-level Rigol.
But any analog scope with an X-Y mode does the job very well, subject to the bandwidth limits.
I haven't used a Tek 502A that you mention, but looking at the manual, it has an X-Y mode and seems well suited to the task.
Offline westfw
« Reply #7 on: November 04, 2014, 05:27:52 am »
November 1975 issue of "Popular Electronics" featured this scope pattern generator:
https://www.acc.umu.se/~polarn-p/sas/Video/ScopeArt.pdf
« Reply #8 on: November 04, 2014, 07:18:36 am »
thanks for your answer and for looking up the XY mode ! ! ! ... analog for the win!
« Reply #9 on: November 04, 2014, 07:20:43 am »
hey, thank you for this info! ... that is surely a nice toy ... however I would like to keep generating patterns from sounds I make with my synthesizers ... so it would be esthetically  pleasing to the eye and the ear ...
Offline GK
« Reply #10 on: November 04, 2014, 11:20:41 am »
Lissajous curves are ultimately a bit boring in comparison to chaotic attractors. For example:
http://www.glensstuff.com/sprottsystems/sprottsystems.htm
Bzzzzt. No longer care, over this forum shit.........ZZzzzzzzzzzzzzzzz
Offline kc0ngu
« Reply #11 on: November 06, 2014, 01:47:16 am »
If I understand correctly this circuit (and those like it) can accept a sound input to translate sounds into patterns.
Just a thought.
« Reply #12 on: November 06, 2014, 02:38:28 pm »
Just a thought.
... well that would be pretty sweet and sure a welcome addition to my synthesizer freuquencies ... I am only 5 hours into Oscilloscopes ...
i am also not into soldering and a pretty bad craftsman ... where can I buy such a fun toy? anybody selling these? anybody willing to make one for me?
cheers  and thanks for reply!
Offline Bassman59
  • Yes, I do this for a living
« Reply #13 on: November 07, 2014, 03:15:00 am »
Have you ever noticed that every movie or TV show that has scenes in a laboratory always has an oscilloscope displaying lissajous figures in the background? (Bonus: sometimes the oscilloscopes don't have anything connected to their inputs!)
With that in mind, I took one of the Silicon Labs 8051 boards that were lying around and programmed it to output the lissajous figures on its two DACs, and connected the DAC outputs to the oldest, ugliest analog 'scope we had in the office. Every few seconds it chooses a new pattern. The only downside is that the 'scope's fan is annoyingly loud. But now my desk looks like Hollywood's vision of an engineering bench.
« Reply #14 on: November 07, 2014, 07:21:52 am »
[/i][/size]
... hi ... googled that board, nothing came up... but I have to say I am so not into electronics, just like 6 hours into scopes ... would sure like to see a picture of your setup ... anyways, could you solder one of these 3d scope imaging  things for me metioned above? ---- thanks for reply buddy
