I'm trying to measure a low A/C voltage with a Microcontroller (varies from 0-1 volt p-p). I realize this is not the 0-5 Volt DC range MC's like to see, but to start, I attached a FW rectifer with a 10uf cap to see if I could get a near DC equivalent (less the RMS value, of course), then send to the MC input analog input pin.
I get no voltage on the output of my rectifier with a 0.8vac p-p. What's the deal? Is this too low voltage for a rectifier to rectify?
Do I need an op/amp or something to boost the voltage, then rectify, then send to the MC?
The larger scope of the project is current measurement - I'm using a current transformer that produces .1 mv per amp of current draw on the secondary winding given a specific burden resistor. That part of the circuit works.
