Hello Everyone,
I moved over to Linux and installed LTspiceXVII. It works more or less.
Not working fully is the transistor selection, there is no menu bar in the selection window, the entries can not be sorted.
Not working is the displaying of power dissipation curves in the Waveform Viewer. When pressing the "alt" key over a component in the schematics window the thermometer appears but no curve is displayed in the Waveform Viewer window.
In the help section only the "Contents" tab is displayed, the tabs for the topics and search (or whatever they are called) are missing.
There probably are other things that does not fully work, this is just after some brief use/testing.
Linux is Ubuntu 18.04 with KDE Plasma 5.12.9 front-end (Kubuntu).LTspice is the latest build, 64-bit version.The LTspice Wine environment is set up with the help of PlayOnLinux (v. 4.3.4).LTspice has its own prefix, or virtual drive, and Wine version is 4.21.The Ltspice user group on groups.io mentions that LTspice has been tested under wine for some time, but they do not give any specifics.It would be nice if LTspice worked as under Windows.
Any help would be appreciated!
Thanks, Peter
