This sounds like a case of two people pissed at each other, without knowing exactly why.
I do think it's a good idea, and I have urged him to reconsider, with more ideas to back it up because I've had so many problems with 2.4Ghz in the past. I also stated reasons why that might be the case, in an attempt to acknowledge the fact that I might not know all the details, and that there are genuine reasons to rely on a 2.4Ghz network.
Halcyon's probably gonna come back and wonder wtf happened/is wrong with us, so I suggest we let whatever stupidity this is cease, brush off hard feelings, and I recommend that you two figure out what's up between the two of you, but that's none of my business.
I think anybody who tries to use wireless communication with any real throughput should understand and expect the limitations. Wireless communications will most likely never be as fast as a direct connection.
I personally use a Ubiquiti Uni-Fi AP-AC-LR, which was I believe cheaper than the pro version at the time. Some people have gone on to say the LR stuff is a bit wank, but despite having no real comparisons, besides a 2011 AP/Router that only does 802.11n 2.4ghz, the range is quite positively impressive. I'm not sure if it maintains 5Ghz the entire way, it might step down to 2.4Ghz, but that is actually another point. Most 5Ghz APs that I have seen are dual band, and will work in 2.4Ghz and 5Ghz at the same time, and in theory should "seamlessly" switch to 2.4Ghz when the 5Ghz signal drops out, and will maintain compatibility with legacy devices.
I actually just installed an 802.11n card into my ~14 year old Prescott Celeron laptop to replace it's 802.11g card that I didn't want to use for fear of bottlenecking other devices (which can happen on some, if not all APs, at least to some extent). I don't know if it's a 5Ghz card, but it hooks up to my AP, and works flawlessly on Arch Linux.
As stated, I'd honestly really only be concerned if I am either running crucial applications (which shouldn't be on wireless anyways), or if the microwave REALLY gets used a lot to the point where severe downtime can be expected.
