Yep. I've never trusted 'Bundled' Earths or Neutrals, for that reason. Not only can you not guarantee
what some shoddy person has done, before, but wiring can not be easily separated during rewiring.
Always use separate Earth & Neutral bars, with the Earth bars having 2 screws per tunnel. They have
separate larger tunnels for the Main-Earth to Ground, and an easily identified M.E.N. (main earth neutral)
link cable to the Neutral bar. If there is no room for them? then the pseudo Switchboard box is not an
approved one, or home made. Treat Earths, with more importance than everything else!!
I had a confusing scenario many years ago, where 2 Neutrals were twisted together, but not connected
properly to the other Neutrals. (3 phase switchboard in a factory). They were for 2 different lighting
circuits, on 2 different phases. They would only come on, if 'both' lighting systems were turned on !!
With 415v across 2 circuits in series, instead of 240v across each circuit !! Was hard to find!!
