I've noticed some comments about opamps sounding different when overdriven, well, that simply means you need to fire your sound engineer.
Seriously, if you're going to overdrive your amplification, there is only *one* simple choice, use freaking vacuum tubes, vacuum tubes have the nicest response when driven to saturation (make sure to bias far away from cutoff), you'll emphasise the even harmonics and get a nice "warm" sound.
Vacuum tubes also have much lower gain than an opamp so vacuum tube amps can't employ much negative feedback so they will be even *less* linear, yay! So you'll get additional harmonic distortion; double yay!
So, throw out your opamps and get to work on those tube circuits. And no, I don't hate vacuum tubes in audio amps, I *love* them, for the only thing they're good for: guitar and bass amps.
Maybe it's my mood this morning, but this thread is driving me ****ing nuts.
If the circuit they're seated in is properly designed, the amp is being fed with proper levels, and the opamp has specs which exceed human perception, it make no ****ing difference at ALL what opamp is in there, period; none whatsoever.
**** (profanity omitted)
edit: fixed spelling/grammar, added more profanity and anger
