What you really mean: You never heard a CD player that produced boatloads of random noise, scratches, rumbling and horrible frequency response.
Well, whatever. I'm happy to have a good turntable. If you're happy with CD then cool.
So you basically want to post-edit the recordings you listen to, by introducing stuff that very likely wasn't there to begin with. That's fine, i have no problem with that. It just has nothing to do with reproducing a record in the best way possible, that is, with the least amount of noise and distortion added.
I'm not interested in what other people consider the best way. I want a Hi-Fi system I like, that's it.
Audiophools should stop pretending that they want the best possible way to reproduce something, but instead simply admit that all they want is to tweak stuff to make it sound the way they like, and not how it was intended to sound.
I'm not pretending anything. I want to tweak stuff to sound the way I like, just as you suggest. But for the fun, let's go along with your implication that it's a poor way to do things and "the least amount of noise and distortion added" is the best.
Well it seems pretty obvious that reducing distortion and noise is the best thing to do and of course, up to a point you are right. Keeping the sound as clean and clear as you can is important. However, while the theory is solid, in practice there are necessary compromises which mean that if you pursue the zero distortion aim too ruthlessly you will destroy your music!
For a start, fidelity to what?? Considering that you pretty much never know what the original source sounded like, how do you know that what you are producing at home is like it? All you can ever do is produce the sound that you
think is realistic, the sound you like. What reference do you have to do otherwise? When you talk about tweaking the sound bear in mind that the recording engineer has already done that. They apply all sorts of EQ, effects, compression and level-mixing in the studio to create a sound that
they like. The sound is unlike the original before it leaves the studio! So again, what is it you are trying to stay faithful to and how can you tell if you are?
Secondly you've the baby/bathwater problem. Having a distortion-free system would be easy if every recording was distortion free but they are far from it. Lets take a simple example. You know how some recordings have spitty treble on the 'S' sounds in the vocals? They are called sibilant sounds and when they are distorted or emphasised it is commonly called sibilance. So you have this spitty treble on some recording and it is clearly a distortion and wrong. What can you do about it? Filter it out, either electrically or mechanically. Soften that area of the frequency response somehow. So you choose speakers or electronics which do not make those recordings sound so harsh. You have less distortion, a step forward.
But hang on. What about the other sounds at the same frequencies? Say the shimmer of cymbals for instance? Or your other recording that sound just fine in that area? The Hi-Fi doesn't know which recording are better rolled off in the treble, it just rolls them all off. So you have a duller sound!
There are all kinds of unwanted resonances and colourations present in Hi-Fi equipment and you have to be very careful about how you go about dealing with it as it is very easy to filter out valuable musical information at the same time. If you listen to a lot of the so-called Hi-End Hi-Fi equipment where excessive damping and filtration has been employed it typically has a very boring, flat and dull sound. Real life is not like that.
And do you realise it would be
impossible to reproduce a proximity to the original sound without adding colouration and no one
ever tries?? Despite what they claim. How can that make sense?
To reproduce only what is on the recording you would have to play your speakers in an anechoic room so that there were no reflections off the walls and furniture to colour the sound. If you've ever heard a speaker in an anechoic room they sound terrible! Utterly dead and lifeless. Why? Because not all of the original acoustic information from the recording venue was captured by the microphones and, even if it was, it cannot be recreated by two speakers. You would need dozens all around the room (which would introduce a boatload of other problems but let's not go there).
So what can you do? You Design your loudspeakers to interact with the listening room to give an approximation of the sort of spacial sound present at the recording venue. Every domestic loudspeaker manufacturer in the world does this. Without room colouration you have an unrealistic sound. So, do you want colouration or not?
Real music is not dull and boring. It is vibrant, energetic and exiting, and coloured! Recorded music should be like that too. Fun, interesting, moving, involving.
Fun. Do you remember fun? ;0)
