I have just finished watching Martin's excellent video review of BRYMEN BM867. Very impressive. It can even challenge Fluke 287 in some areas. So I checked the its little brother, BRYMEN BM857A. The 857A is very similar to 867 in most areas, only missing the dual display.
Here are the headline features that's very attractive:
50,000 counts (500,000 counts in DCV high resolution mode)
42 Segments/60Hz
5x/s sampling rate
0.03% accuracy
Up to 9999uF
Cost 107 EUR
So for 30% higher price, it is at least 2 steps above the $100 crop.
The only con I can find is the backlight. Is it very terrible?
So now since Amprobe AM-270's size has been corrected, I'm torn between them. They are roughly the same size, good in almost every way, and share the same bad backlight! BRYMEN BM857A is at least 50% more expensive, but has much better resolution and accuracy.
Or should I bite the bullet and go for the 867. That should have absolutely zero cons?
