Five years ago, I decided to build my dad a modular Eurorack synth for his 60th birthday, and I finally placed the order!
I've done mostly digital designs and embedded programming (fix it in software), so this has been a steep learning curve.
After countless hours of simulation, breadboarding, and test PCBs, here are the modules I've designed — built on topologies and ideas gathered from the synth community:
- ADSR: Listed as EG (Envelope Generator) on the panel. Looping mode doubles as an LFO
- ATT: Simple attenuator
- DIST: Diode clipping distortion
- FIL: Voltage Controlled Filter with a diode ladder design
- MIX: Four-channel mixer; the fourth channel adds DC offset when no jack is plugged in
- NOISE: Generates white and bright noise (-3dB at 1.5kHz). Integrated slew limiter for portamento
- OUT: Dual channel mix and pan with line and headphone outputs
- SUB: Logic divider producing square wave outputs at 0, -1, and -2 octaves
- VCA: Dual voltage-controlled amplifier with pot or CV control
- VCO: Sawtooth output with FM; pulse width output with CV-adjustable width
- MULT: 8 jacks. Either 1 to 7 or two sets of 1 to 3
I've let out smoke, broken LEDs, and made opamps oscillate when they shouldn't; it's been worth it. I'm much less scared to prototype audio circuits, and much more thankful for my oscilloscope and triple power supply
It's been a while since I've posted, and a wall of text about analog synth design is probably random from me, but I had to share with people who might appreciate it (my wife don't, hehe). Thanks for reading!
PS: The panels are white since my brothers and I will paint and lacquer them. We discovered black silk screen doesn't show through paint, but they are handy when picking up a panel to paint and label.
