Author Topic: Need a transformer  (Read 3688 times)
Offline easilyconfusedTopic starter
Need a transformer
« on: July 27, 2010, 01:45:13 am »
I burned up the transformer in my Radio Shack Electronics Learning Lab. They don't list any parts for them as far as I can tell. This thing was glued in. I'm sure it wasn't intended to be replaced. Just the same-- I'd like to repair it if possible. It's got this number on top but it doesn't Google up. 102381690A. I realize any number of vendors may have stuff like this but I don't know how to do a search. Any suggestions? Thanks
Offline joelby
Re: Need a transformer
« Reply #1 on: July 27, 2010, 02:16:06 am »
Jaycar sells one:
http://www.jaycar.com.au/productView.asp?ID=MM2532&keywords=MM2532&form=KEYWORD
As per your diagram, the primary impedance is 1K centre tapped, the secondary 8 ohms.
« Reply #2 on: July 27, 2010, 02:41:36 am »
Jaycar sells one:
Thank YOU! That's it exactly!
Online Zero999
  • 0999
« Reply #3 on: July 27, 2010, 09:05:07 am »
Where do you live?
If it's in the US there's Digikey, order number: 146KHM-ND
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=146KHM-ND
http://www.hammondmfg.com/pdf/5c0045-46.pdf
It's much more expensive though, it's probably cheaper to buy a new learning lab and use the old one for spares.
