Author Topic: Need help to identify this IC  (Read 1794 times)
Offline Icuol2218Topic starter
  • Country: my
    • n/a
« on: June 16, 2026, 08:06:31 am »
Hi, can someone tell me what is this IC for ? I seach the internet look for the datasheet but only found a datasheet for different device.
« Last Edit: June 16, 2026, 08:13:28 am by Icuol2218 »
Online squadchannel
  • Country: jp
  • deepl translate user
Re: Need help to identify this IC
« Reply #1 on: June 16, 2026, 08:08:21 am »
this?
Online squadchannel
  • Country: jp
« Reply #2 on: June 16, 2026, 09:17:37 am »
Custom module. Switching controller. There's no datasheet.
made by Eta Electric Industry. already bankrupt.
The following users thanked this post: amyk
Offline u666sa
  • Miami, FL
    • Codernov Electronics Repair
« Reply #3 on: June 16, 2026, 05:35:15 pm »
EH12AA
Digital Hall-Effect Sensor 3.8V to 30V
EH12AA Description
EH12AA is a high-performance, low-noise, 12 V switching regulator designed for stable power delivery in industrial and consumer electronics. It features integrated MOSFETs, enabling efficient operation with minimal external components. The device supports wide input voltage ranges and offers excellent load and line regulation, making it ideal for applications requiring reliable DC-DC conversion.
Key Parameters
Parameter   Value
Output Voltage   12 V
Input Voltage Range   8.5 V to 36 V
Maximum Output Current   3 A
Switching Frequency   500 kHz
Operating Temperature Range   -40°C to +125°C
Quiescent Current   70 µA
Efficiency   Up to 95%
Package Type   TO-263-5 (D²Pak)
Protection Features   Overcurrent, Overtemperature, Short-Circuit
Replacement Models
For equivalent or improved performance, consider the following models:
EH12AB – Enhanced thermal performance and higher current capability.
EH12AC – Supports lower quiescent current and improved efficiency at light loads.
EH12AD – Optimized for compact designs with reduced footprint.
https://www.utsource.net/itm/p/9224972.html?srsltid=AfmBOoodphWklJ-pd6JmYrwVpvVdn9hOlWhEAZubmLs5QfcuDntl4f_s
Offline SiliconWizard
« Reply #4 on: June 16, 2026, 05:37:22 pm »
Really? Is it a Digital Hall-Effect Sensor or a switching converter?
Offline u666sa
  • Miami, FL
Offline u666sa
  • Miami, FL
Offline u666sa
  • Miami, FL
« Reply #7 on: June 16, 2026, 05:42:09 pm »
low-noise, 12 V switching regulator make more sense.  :blah:
Offline Alex Eisenhut
  • Place text here.
« Reply #8 on: June 17, 2026, 11:30:46 pm »
A switching converter in the worst possible package and no inductor nearby?
"Package Type   TO-263-5 (D²Pak)"
Nope...
Offline fzabkar
« Reply #9 on: June 18, 2026, 01:03:26 am »
This listing suggests that the manufacturer is Nichicon:
https://www.aliexpress.com/item/1005009749808503.html
I don't believe it, though.
This would appear to confirm @squadchannel's post:
https://www.yuyiplc.com/products/9317/image/ETA%20ELECTRIC%20INDUSTRY%20POWER%20SOURCE%20PLE24HSZ_2.jpg
« Last Edit: June 18, 2026, 01:11:03 am by fzabkar »
Offline amyk
« Reply #10 on: June 18, 2026, 02:14:54 am »
What's the machine it's found in? It appears to be of Japanese origin; they were well known for using hybrid circuits in SIP packages like that.
Online squadchannel
  • Country: jp
« Reply #11 on: June 18, 2026, 02:35:01 am »
It's Eta, it must be a SMPS.
Looking at the photo, it seems like there’s just an IC and a capacitor.
probably something like the SO-16 type. so if you soak it in acetone, it might be able to figure out what it is.
« Last Edit: June 18, 2026, 02:40:05 am by squadchannel »
  • Country: my
    • n/a
« Reply #12 on: June 26, 2026, 04:53:44 am »
Yes, it is ETA
