A few minor googled items.
https://www.kane.co.uk/knowledge-centre/what-are-safe-levels-of-co-and-co2-in-rooms 250-350ppm Normal background concentration in outdoor ambient air
350-1,000ppm Concentrations typical of occupied indoor spaces with good air exchange
1,000-2,000ppm Complaints of drowsiness and poor air.
2,000-5,000 ppm Headaches, sleepiness and stagnant, stale, stuffy air. Poor concentration, loss of attention, increased heart rate and slight nausea may also be present.
5,000 Workplace exposure limit (as 8-hour TWA) in most jurisdictions.
>40,000 ppm Exposure may lead to serious oxygen deprivation resulting in permanent brain damage, coma, even death.
400ppm = 0.04%
2000ppm = 0.2% (Roughly Earth's average through the Permian, Triassic, Jurassic, Cretaceous and Tertiary ages, ie the past 250 million years.)
5000ppm = 0.5%
Note that the observed effects in the text above for 1000-5000ppm CO2 in enclosed spaces probably has more to do with the drop in oxygen content you'd expect in those circumstances. The primary effect of increased blood CO2 is faster respiration, since the body uses blood CO2 sensing to control respiration rate. There is no blood oxygen sensing, but the effect of low oxygen in drowsiness and eventually loss of consciousness.
http://www.val-tronics.com/downloads/appnotes/NOTEA11.PDFCarbon Dioxide in air (volume %) Increased lung ventilation
0.1 to 1.0% (1000 to 10,000 ppm) Slight and unnoticeable increase
2.0% 50% increase
3.0% 100% increase
5.0% 300% increase, breathing becomes laborious
Ten percent (10%) in air can be endured for only a few minutes. Twelve (12%) to fifteen (15%) percent soon
causes unconsciousness. Twenty-five (25%) percent may cause death in exposures of several hours. The
normal concentration of CO2 in fresh air is 0.03% to 0.04% (300 to 400 ppm).
I know from my own caving experience, 2% to 3% CO2 is really noticable. Below 1% (10,000ppm) you wouldn't even know, so long as Oxygen stays up over 19%.
google: greenhouse farming ideal co2 level
http://www.novabiomatique.com/hydroponics-systems/plant-555-gardening-with-co2-explained.cfmGardening with CO2 explained
How much CO2?
It is well known that a CO2 level in the garden's air between 700 and 900 ppm improves crop development and yield. Most plants grown for their beautiful flowers or foliage optimally develop at about 800 ppm. Roses are distinctive as they require about 1200 ppm in carbon dioxide concentration for best results. For many fruits and vegetables, the ideal CO2 level in the garden should be at least between 1000 and 1200 ppm.
google: increased co2 reduces plant need for water
http://www.co2science.org/subject/t/summaries/transpiration.phpThese several results, as well as those obtained from many other studies, suggest that as the air's CO2 content continues to rise, earth's plants will likely display reductions in stomatal conductance, which should reduce their rates of transpirational water loss. As a result, most plants should be able to better deal with periodic water shortages and warmer temperatures, possibly even expanding their ranges into areas where it was too dry for them to successfully live and reproduce in the recent past.
We're already seeing this effect. Lots of reports of long-established desert areas starting to green-up now. One amusing side effect: Mad Max Fury Road having to be shot in Namibia since the original 3 Mad Max movie locations in Australian desert were 'too green'.
Ha ha... I see there are now some Warmist studies attempting to show that reduced plant expiration of water vapor would be a bad thing, because... drier local climate. Except the ones I skimmed made the assumption total plant biomass would remain the same. Which is insane. and the kind of ridiculous thing you would only assume if you were groping for something bad to say about results of increasing CO2, and hoped no one would notice you being a jerk.
google: sea levels geological history
http://www.curry.eas.gatech.edu/Courses/6140/ency/Chapter10/Ency_Oceans/Sea_Level_Variations.pdf300 meter variations and more, with many dramatic swings. Take that 70mm variation and stick it. If it's even real/accurate, see next URL. Also you
do realize we're still emerging from the last ice age, right? There are innumerable instances in all civilizations of sea ports ending up 50 meters and more under water or up on hillsides. People adapt. That our present civilization is so stupid that we build massive cities on 'at sea level' flat land is just a demonstration of short-sighted stupidity, not any kind of argument about climate change. Which will continue no matter what we do. As for New Orleans... good grief.
http://wattsupwiththat.com/2014/04/28/sea-level-rise-slows-while-satellite-temperature-pause-dominates-measurement-record/Dr. Curry draws the following conclusions based upon these measured and perhaps interrelated outcomes by noting:
“Once again, the emerging best explanations for the ‘pause’ in global surface temperatures and the slow down in sea level rise bring into question the explanations for the rise in both in the last quarter of the 20th century. And makes the 21st century of sea level rise projections seem like unjustified arm waving.”
Also yet another fine example in the opening there of how warmists routinely 'adjust' data to fit their expectations.
Oh, and don't forget to check out 'post glaciation crustal rebound' for extra fun.
