Transformer doesn't look too bad, and will clean up well. Just pop it, after removing from the chassis, and a good going over with a stiff nylon brush to remove dust and loose rust, into an oven at 105C for 6 hours to dry it out, then when at 40C again spray with a few coats of clear lacquer to provide some waterproofing for it and keep it dry. Then you can use a dim bulb tester to see if it has survived.
You will just have to be careful of that SRBP, it might need the same bake treatment as well, but at least there you will be replacing pretty much every capacitor anyway, and every resistor that is over 10k as well, using at a minimum 1W metal film, as they are about the same size, can withstand the high voltage and will not drift high in value like the carbon composition ones. Valve bases will survive the oven no problem, even if they are plastic they need to survive being toasted by the heaters anyway. Have fun with cracked traces, and careful of them pulling off, that Paxolin board is famous for lifting with heat.
