Thanks.
Some other information about this? i want to make a +/-10V and 1A PSU from a transformer.
Well, maybe if you get 15/15V out of the transformer, rectification and regulation will drop the range roughly to 10 or 12V... an LM317 can get you 1.2-10V, and an LM337 will do the same except for the negative rail! You can do some tricks with an op-amp to offset 1.2 to 0V if going down to 0V is important...(assuming you mean adjustable of course!)
So in other words, a split secondary (or centre tapped secondary) transformer is what you need to start with. Anywhere from 12 to 18 sounds good... Try to find what VA rating you need yourself as a learning exercise.
Constant current should not be too difficult to add, just an op amp, sense resistor and fet might do it...
