Author Topic: Post your components of unusual physical size  (Read 9260 times)
Offline PsiTopic starter
« on: May 29, 2011, 12:39:28 pm »
So you have some electronic component or test gear which is either unusually big or unusually small.
Post it here so we can have some laughs.
Here's two ultra tiny meters next to a NZ one dollar coin.
« Last Edit: May 29, 2011, 12:52:48 pm by Psi »
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: Post your components of unusual physical size
« Reply #1 on: May 29, 2011, 09:23:35 pm »
The cutest little CRT - from an old camcorder viewfinder
Day Job: Mostly LEDs
« Reply #2 on: May 30, 2011, 08:24:25 am »
haha,  aww that is cute
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #3 on: May 30, 2011, 10:11:25 am »
A CRT view finder ? kind of smacks in the face of being told as a kid to sit a certain distance from the screen  ;)
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #4 on: May 30, 2011, 02:45:21 pm »
my entry for darwinian cup... 1n4148 smd fullbridge rectifier... with thorn.
Offline Lance
  • Resistance if futile if R<1Ohm
« Reply #5 on: May 30, 2011, 02:50:05 pm »
Neat! Controlling that would be an interesting project.
#include "main.h"
//#include <killallhumans.h>
Offline Zero999
  • 0999
« Reply #6 on: May 30, 2011, 06:45:04 pm »
Is it monochrome? It looks like it.
« Reply #7 on: May 30, 2011, 11:29:11 pm »
Yes - would be rather tricky making a shadowmask tube this small...
Not much point as the viewfinder usually contains all the drive electronics and just needs power and a comp. video signal. Unfortunately it doesn't look as cute once the scan coils are on.
Offline JohnS_AZ
    • About.me
« Reply #8 on: May 31, 2011, 12:02:26 am »
I bought a heatsink off of eBay about 5 years ago ....
http://hackersbench.com/Archive/hfh/
I'm either at my bench, here, or on PokerStars.
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« Reply #9 on: May 31, 2011, 12:31:30 am »
The same micro buttons that Dave liked that much on the Metrawatt Energy,
are inside in my Olympus camera !!  ( Made in Japan )   ;)
Offline Trigger
« Reply #10 on: May 31, 2011, 02:08:40 am »
I've got a box full of some Maxwell Boostcaps
http://www.goldmine-elec-products.com/prodinfo.asp?number=G17960
I have a few future project ideas for them when I have one of my evil mad scientist moments  ;D
« Reply #11 on: May 31, 2011, 02:36:26 am »
hehe, i have 9 of those in series which i charge up and short out with a 600A load when i've had a bad day :D  always makes me happy.
I also use 6 in series if i need to jump start a car.
Offline TheWelly888
« Reply #12 on: May 31, 2011, 08:52:54 am »
Hi John, I suspect that big bugger was built to supply traction motors such as those used in electric locomotives or shipping, the volts and amps ratings looks about right.
You can do anything with the right attitude and a hammer.
« Reply #13 on: May 31, 2011, 09:44:37 am »
Here's a massive valve from an old high power transmitter.  I believe it was used at an airport.
Quick google found this info
"Eimac 450TL, measuring 12.5" tall by 5" across the bulb. This is a directly heated triode transmitting valve, 7.5V/12A filament, 4kV to the anode."
AA battery shown for size
« Last Edit: May 31, 2011, 09:49:15 am by Psi »
Offline dengorius
« Reply #14 on: May 31, 2011, 10:21:34 pm »
Lol that really is the heatsink from hell. Now I understand why it is so hot over there, they can't dissipate anymore :D
Offline Frangible
  • Contraptioneer
« Reply #15 on: June 02, 2011, 02:37:33 am »
I used to have one of those that I pulled from a defunct philips cassette player.  I ended using it in a QRP SWR meter I used to tweak antennas when I used to backpack radios out into the boonies.  I remember it using a 1mA movement.
« Reply #16 on: June 02, 2011, 06:05:52 am »
heh,
The ones i have could easy have been out of a Philips cassette player. I remember there was an old Philips player around here many years back
Offline Lance
« Reply #17 on: June 02, 2011, 03:45:07 pm »
Can you still get meters like that?
#include "main.h"
« Reply #18 on: June 02, 2011, 04:13:09 pm »
cant say ive seen any for sale
Alex
  • Guest
« Reply #19 on: June 02, 2011, 05:59:54 pm »
Here is my entry for the smallest, most widely used and most crucial component in electronics.
  • Country: my
« Reply #20 on: June 02, 2011, 06:06:23 pm »
yea right too small i cant see a thing
Offline apex
    • Thoughts of a nerd
« Reply #21 on: June 02, 2011, 06:07:28 pm »
Let me guess:
It's air?
For isolation?
apex
Offline Rufus
« Reply #22 on: June 02, 2011, 06:27:34 pm »
Not a component but I have always been impressed with my old Sony WM-101 walkman cassette player.
With the flat 'gum-stick' battery pack it is exactly the same size as a plastic cassette case.
I often wondered what the guy sitting at a drawing board designing the plastic cassette case would have though if someone told him they were going to fit a complete auto-reversing player and battery in the space he left behind.
Offline Murphy
« Reply #23 on: June 02, 2011, 09:16:45 pm »
I have one of those huge heatsinks too... mine has SCRs in it.
Offline Lance
« Reply #24 on: June 03, 2011, 09:14:07 pm »
Darn. I could use some small dials like that.
#include "main.h"
