Author Topic: Power strip, a global demand, any recommendations?  (Read 19227 times)
Offline StoreinfinityTopic starter
  • Country: cn
  • StoreInfinity thinks decent,different and longterm
    • StoreInfinity
« on: November 07, 2011, 08:27:18 am »
Power strip:
according to Wiki.org,(http://en.wikipedia.org/wiki/Power_strip) "In 1972, the electrical "power-board" was invented by Australian electrical engineer Peter Talbot working under Frank Bannigan, Managing Director of Australian company Kambrook. The product was hugely successful, however, it was not patented and market share was eventually lost to other manufacturers."
I've seen some really good designs yet still am using traditional old ones.
Anyone tried stuff the same or similar?
I would like to know some popular options when it comes to power oscilloscopes and multimeters etc.
Many Thanks and Wish you all the best.
By the way
Today is Eid-al-Adha day!
Worldwide muslims celebrate this every year for three days.
As a Kazakh this festival is pronounced into Kazakh as ?????? ??? (Qurban ayt).
See more: http://en.wikipedia.org/wiki/Eid_al-Adha
http://www.timeanddate.com/holidays/us/eid-al-adha
http://www.keywordspeak.com/2011/10/november-7-2011-is-holiday.html
http://nation.com.pk/pakistan-news-newspaper-daily-english-online/Regional/Lahore/07-Nov-2011/Eidul-Azha-being-celebrated-today
A lot of notorious online sellers cheat or rip off while we do not bother; We work hard to be constantly refined as a decent, reputable and life-long reliable distributor for people in this field. We now live in Shanghai, a city of vibe with over 30 million people. Come and check this place out!
Offline Ronnie
  • Country: ph
  • Stimulating your Ears
Re: Power strip, a global demand, any recommendations?
« Reply #1 on: November 09, 2011, 05:04:07 am »
I'm using APC (American Power Conversion) brand. I have a unit bought sometime 1998 still working fine   8)
Offline sonicj
  • updata successed!
« Reply #2 on: November 10, 2011, 04:39:04 pm »
i like the Tripplite PS3612. nice spacing for wall warts. power switch guard. lifetime warranty. the mounts aren't that great, but they work.
-sj
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #3 on: November 10, 2011, 06:59:26 pm »
For general purpose power strips the best quality use metal casings for long term durability, but it cost so much more because the contacts have to be isolated from the chassis and the chassis grounded for protection.  Plastic thus are just as fine and can last decades so long as its kept away from sunlight, as UV causes many plastics to degrade unless they are UV treated, which just prolongs its lifespan not last for lifetimes such as an all metal case.
http://www.rutlandplastics.co.uk/plastics_additives_stabilisers.shtml
Less moving parts, and single long strip is the most hardy kind.   Even no name Chinese label ones are fine, I pick them up for $1-2 each during special deals and all have universally a circuit breaker that also doubles as an on-off switch.
A power strip is a separate issue from a surge protector.
Best Wishes,
 Saturation
Offline benemorius
« Reply #4 on: November 11, 2011, 02:02:56 am »
-sj
I freaking love these. They have a whole range of sizes. I didn't like the mounts at all when I first saw them, but they hold much better than I expected. I have always considered that I could email Tripplite and get extra ones for more stability if I wanted to, and probably at no cost to me. They're a reputable company.
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #5 on: November 11, 2011, 02:29:50 am »
Go for the max joules for the buck.  then make sure it can hold wall warts.  like this: http://www.walmart.com/ip/Belkin-BE112234-10-SurgeMaster-Professional-12-Outlet-Surge-Suppressor/13073631      3960 joules for $25.00
Offline requim
« Reply #6 on: November 11, 2011, 02:38:02 am »
The belkin looks nice with a good price, however if we're talking about more joules, this is probably a better deal for a few dollars more.  Same # of jacks (12) but goes to 5000 joules instead:
http://www.amazon.com/MonsterDigital-PowerCenter450-HPM-MDP-450/dp/B002RL9XQM/ref=sr_1_1?ie=UTF8&qid=1320979009&sr=8-1
Offline robrenz
« Reply #7 on: November 11, 2011, 03:04:04 am »
Agreed, I actually have a 5000 joule phillips unit but I could not find it for the post.  You did a better job of searching than I did.
Offline saturation
    • NIST
« Reply #8 on: November 11, 2011, 03:55:26 pm »
High joule rating for a surge protector is a misconception.  Here's a thread on it from a year ago.
https://www.eevblog.com/forum/index.php?topic=381.msg19635#msg19635
http://en.wikipedia.org/wiki/Surge_protector#Joules_rating
Based on work done by NIST, a joule rating of over 100 is adequate.   Over 300 joules allows for a 3x derating is likely more you'll ever need.
Best Wishes,
 Saturation
Offline robrenz
« Reply #9 on: November 11, 2011, 04:08:20 pm »
Would the higher capacity in joules (more or larger MOV's) equate to yielding a longer life?
Offline saturation
    • NIST
« Reply #10 on: November 11, 2011, 08:28:19 pm »
Hi robrenz,
It could.  But its hard to say what will happen.
MOV work by shunting the surge current to ground; if the ground is somehow removed [ that's why good surge protectors have a ground fault light] the MOV will absorb the energy.
A high joule rating [ akin to a high watt rating on a resistor] will then absorb more energy before it blows, and MOVs that blow are like a flare and very hot.  At worst it can melt plastic cases and if it breaks through, can burn the surrounding area of the surge protector, like a carpet or a sofa.  These high joule MOV are best in all metal cases.  If the MOV absorb the energy and do not blow, then nothing likely will happen, and the good news is the partially damaged MOV will likely blow at lower energy at the next surge, whenever that is.  The downside is that high joule rating MOV are a fire risk.
To avoid this, plastic cased surge protectors are best with small joule MOV, so they will die quickly and not have too much energy to dissipate.   Many surge protectors from reputable power product companies like APC bypass the hype and usually just have 300-500 joule MOV inside them and will offer a lifetime guarantee on the product, because surges that damage protectors are fairly rare and the cost to replace the unit truly small.
To get higher joules some surge protectors makers either parallel multiple 100-500 joule MOV or use one of the newer premade single unit parallel MOVs.
MOV are non-linear and when faced with surge voltage, identically label MOV will not act identical, some will have let through voltages lower or higher than spec.   This causes one of the units in parallel to blow sooner than others, so you don't have the violent burn expected of a single high joule MOV.
Alas, better designs include a thermal fuse in series with the MOV.  If the MOV overheats, the fuse will blow, cutting off the MOV from the line thus preventing an explosion.  If this design is used, all the joule ratings become moot, because the thermal fuse is often designed to trip before the MOV can explode, making high joule ratings unnecessary.
Better designs have MOV also linked by a thermal fuse to the HOT side of the AC line.  If the MOV overheat, the HOT line thermal fuse will blow, killing all power to units serviced by the the surge protector, again preventing a MOV fire but also killing the whole protector.
Thus, in the end high joule ratings are a fire risk, and if thermal fuses are used, will unlikely provide the benefit of making the surge protector last longer against surges.
Best Wishes,
 Saturation
Offline robrenz
« Reply #11 on: November 11, 2011, 08:36:15 pm »
Thanks saturation,  very informative.  I never thought about the fire risk of the plastic cased units.
Offline saturation
    • NIST
« Reply #12 on: November 11, 2011, 09:08:38 pm »
You're welcome.  Here are some links to discussions of surge supressor fires.  With thermal fusing, these events are fairly rare, unless the surge protector manufacturer doesn't use them.  I open mine to insure they are built this way.
http://www.nmsu.edu/safety/news/lesson-learned/surgeprotectorfire.htm
Fowler is an investigator and focuses on fires caused by surge protectors and power strips:
http://www.sfowler.com/investigations/Surge%20Protectors.htm
this is how violent a MOV fire is when faced with large surges:
Best Wishes,
 Saturation
Offline McMonster
    • McMonster's blog
« Reply #13 on: November 12, 2011, 04:11:45 pm »
Thanks for the info saturation, don't you think this is worth putting on EEVBlog's wiki?
Offline saturation
    • NIST
« Reply #14 on: November 12, 2011, 05:35:50 pm »
you're welcome.  I didn't know there was a wiki, feel free to copy it there and I'll edit it if needed.
I helped write the Wikipedia one, but the other contributors fixed it up nicely.
You're more than welcome to add more or ask more about them; I spent time talking to Francois Martzloff at NIST, the 'surge god' and then Robert Standler, about some of the industry 'wierdness' about the consumer side of this industry.  The professional side is ok but what they do for consumer products is certainly worth an expose.
For more details, read this review on an APC surge protector, as the details also discuss the strange activities in the industry:
http://www.epinions.com/review/APC_11_OUT_SURG_W_TEL_COA_EA_APNP11VNT3_Surge_Suppressor/content_453665328772
Best Wishes,
 Saturation
Offline don.r
« Reply #15 on: November 12, 2011, 07:40:12 pm »
For my bench, noise filtering is usually the number one concern, second is number of outlets and spacing. Its nice to see strips come with spacing for bricks now and rotating/swiveling sockets as well. The I find the cheap home strips need to replaced occasionally as I find the surge protection becomes inadequate over time (perhaps a few years). I live in an area with fairly noisy lines with frequent transients so this may play a part.
Offline saturation
    • NIST
« Reply #16 on: November 12, 2011, 08:41:38 pm »
Yes, it certainly can.  I rarely have mine blow, I had one APC fail explosively after 12 years, and it was over 12 years old.
If you replace them frequently, a MOV only costs about 50c, a thermal fuse MOV combo about $1.60, and if they failed but the associated fuses are intact, you can replace them cheaper than buying a new surge protector.
If you buy an APC model they have a good history of honoring the lifetime warranty on failed SPD's for free for life, AFAIK.  After my APC blew, I contacted APC and they sent me a new one  in the mail even before I mailed mine out.
http://www.amazon.com/review/RX94MQ90PBJM8/ref=cm_cr_pr_perm?ie=UTF8&ASIN=B00000J3WW&nodeID=&tag=&linkCode=
An example of a bad experience with a surge:
http://www.amazon.com/Belkin-F5C895-TEL-SurgeMaster-8-Outlet-Protector/dp/B00000J1RU/ref=wl_it_dp_o_npd?ie=UTF8&coliid=I3RZVU2J95MR80&colid=EIWMTQB99Q0R
UL 1449, the spec for SPD, changed recently, and any home SPD over 10 years old is obsolete,  if they don't have thermal fusing it should be upgraded or modded by the owner otherwise its a fire risk.
Best Wishes,
 Saturation
Offline entereev
« Reply #17 on: March 04, 2012, 06:46:41 pm »
Sorry for thread necroing, but this is interesting. Often there are places with no grounded outlets whatsoever, so I'm forced with this temporary handicap. So my question is: Does any kind of surge protector work this way (MOV energy absorbtion) without a grounding?
What you're saying is quite positive considering what all the naysayers on the interwebz are claiming
Offline FenderBender
    • The Solid State Workshop
« Reply #18 on: March 05, 2012, 01:03:02 am »
TrippLite Isobar has been an industry standard surge suppressor.
I know this is a marketing picture but I can't say that it should be too far off...
alm
  • Guest
« Reply #19 on: March 05, 2012, 01:37:05 am »
Are surges really your biggest worry if the installation lacks any ground connection? I would avoid using any IEC class I equipment, like desktop computers and oscilloscopes, which rely on a solid ground connection for safety in case of faults. Using a class I appliance without ground connection will often result on a high-impedance mains/2 voltage on the case due to the capacitive divider in the EMI filter and can expose the user to mains voltage after a single fault, as opposed to class II equipment or class I with ground connection, which is designed to be safe in the case of a single fault. Class II appliances don't require (or have) a ground connection, so they should be safe.
Offline T4P
  • Country: sg
    • T4P
« Reply #20 on: March 05, 2012, 04:26:44 am »
So basically you want to avoid desktop computers ?  ::) Sadly people still want to use desktop computers , unless you live in a cave .
But i would question whether you typed that on a laptop or a desktop  :-X
Offline nukie
« Reply #21 on: March 05, 2012, 11:23:47 pm »
I prefer power strips with individual switches.
Hello alm,
can you please elaborate further regarding these class II equipment? What are the common class II equipment and how do we tell them apart without looking at the wiring?
Offline WBB
« Reply #22 on: March 06, 2012, 01:57:33 am »
I'll give another vote to the Tripplite units. They really should throw a couple extra mounts in the box, but the units themselves have fantastic build quality. I've always plugged them into cheaper 2 outlet surge protectors hoping it would sacrifice itself in case something really bad happened and save the Tripplite. So far that's worked quite well.
Offline cybergibbons
« Reply #23 on: March 06, 2012, 07:39:55 am »
I'm really not keen on having surge protectors in power strips for a few reasons:
  • Combining the two means you'll be making compromises with both
  • I hate the idea of having distributed fire starting boxes around my house
  • In London, power is very, very clean in terms of surges and overvoltage. The maximum overvoltage we have had is around 12V in the last 2 years. I don't measure for quick transients, but have no reason to suspect there are any. Benefits of underground cables.
alm
  • Guest
« Reply #24 on: March 06, 2012, 09:21:37 am »
Then have an electrician install grounded sockets.
On a battery powered laptop without any mains or ground connection, your point being?
I'm talking about IEC protection classes. The most common by far are class I and class II.
Class I equipment, which always has a grounded plug, requires only single isolation for any conductor, but relies on a grounded case to prevent a single fault from being harmful. A fault (eg. damaged insulation) will result in a short to ground, which will blow the fuse or GFCI. Without ground, it would result in the case being elevated to mains potential.
Class II always has an ungrounded plug, and relies on double insulation instead of grounding. Clearances and creepage distances are doubled, and conductors might have two layers of insulation or reinforced insulation around conductors. This makes the chance of someone coming into contact with hazardous voltages equivalent to the occurrence of two faults.
Class II equipment is becoming more and more common since it's still safe in the absence of a ground connection.
