This is a good reminder that just because you don't know why something works the way it does doesn't mean the engineers were high, mmkay?
I agree with this but it also doesn't mean the engineers always get it right.
And sometimes things which may be justified from a technical point of view can be annoying to the consumer.
And I realize many things change to satisfy the public at large even though they may be annoying to me in particular. The manufacturers are looking for the large market share, not outliers.
But then how much hot water gets wasted? (In the form of hot water in the pipes that cools off.) It may or may not be saving you money in the end. Remember that a modern washer uses extremely little hot water in the wash phase (like around 10l for a medium size load). Unless the washer is right next to the hot water heater, there might be that much just in the pipes...
Not a consideration in my case although I acknowledge that it might be relevant in most cases.
The enzymes in modern detergents don't need high temperatures, and in fact some of the enzymes are deactivated by heat. The detergents are, in fact, designed to do different things at different temperatures, so it's actually desirable for the wash to heat slowly.
This is all very well but we have turned doing a load of washing into a high-tech process where I have lost control whereas thirty years ago it was simpler and I had total control.
Now I give my clothes to the washer and I lose control of what happens. I cannot add clothes, I cannot speed up the process, I cannot do anything but submit to the higher authority of the washer and humbly collect my clothes when the washer is ready to return them.
I used to be able to have much more control over my washer and I liked it that way. Again, this is just me; I realize the big market consumers may prefer the way things are going now.
When I have a very small load of maybe just some underwear I will just do it manually in one of those big plastic paint buckets rather than use the washer. In fact, I have been thinking of inventing some way to hang the bucket and have a small motor shake it a bit. Maybe I should open a thread to discuss this
