I can already imagine people thinking “what has this to do with Electronics”.
Maybe not so much, I could go on a CNC forum and post it there but lately a lot people are joining us here on EEVBlog forums with different background than only Electronics and also there is some Electronics involved with CNC machines like controllers and such.
I did work with milling machines but never with a CNC machine, so this is a fun project for me and I also will learn a lot if I build it myself, any advice and help form CNC gurus we got on the forum will be greatly appreciated.
If moderators or Dave think this doesn’t fit on this forum, please delete or lock the topic, no harm done
That being said, I mention earlier in some topics I got a Proxxon MF70 milling machine and wanted to convert to a CNC milling machine. It is a fairly small machine and fits nicely on my Electronics bench and it has its limits like not having big work area but still good enough for small things.
I was building a half wood, half Plexiglas box for my other equipment to keep things clean on my bench if I had to drill or saw something, but the milling machine fits there nicely too, probably I will add a top part to make it enclosure box but right now the shelf above is in the way because the milling machine is just little too high but I will find something for that :
Before we go further, I am trying to keep the costs low as possible so getting cheapest possible parts to make it work. I already have a Windows XP machine ready for this with Mach3 CNC on it.
I got the stepper motor mounts here, these are made for Nema 23 stepper motors, the reason I got this one is: I can’t make one myself because I don’t have access to a metal working shop as years ago. This one was cheap but also didn’t have rounded edges like most sets out there and that makes for me easy to mount the limit switches. Also there is no need to change anything on my milling machine, even spindles will stay as they are, I only need to remove the little black handle on them.
I already ordered a 3 axis CNC controller with a Toshiba TB6560AHQ chip, this is very common controller and it supports stepper motors till 3A each axis:
I also ordered a 24V 15A switching power supply:
I am not sure if its worth mention but I will use switches below for limit switches, I will get two emergency stop buttons later on, one for the controller board to stop the program if things go wrong without cutting off its power and one for real emergency to cut off the power totally on the board and the PSU:
Here is the tricky part, at least for me. I didn’t figure out what stepper motor to get, it has to be a Nema23 but I am not sure what torque and size. The other thing I want it a double shafted stepper motor because I want to be able use the milling machine without CNC part for small projects but maybe someone can make this clear; does Mach3 lose any setting if I turn on the stepper motors manually?
After a lot reading around the motor below should be perfect fit power wise and it has double shaft. It is fairly heavy with 0.7kg on each stepper motor but the smaller ones don’t have the torque I need. It is a Nema23 57BYGH56-401B
Here some specs and photo of the motor:
So any of the CNC guru’s out there have some tips for me? Am I doing good so far or do I have to change something in my further plans?
