I used to hate Tek scopes with passion, and now I have to say, eff you Tek service centers.
About 3 years ago I sent my Fluke 289 to a nearby Tek calibration center, and they were kind enough to replace the old batteries, which is good.
Until today I found out one of the 6 batteries is leaking and has already corroded a negative battery contact spring.
Not only it corroded the spring contact, it also left quite some crystals and liquid nearby in plastic parts, and thank god the electrolyte doesn't corrode plastic.
So, my question is, is there s non leaking battery available out there? I've been using Energizer for years without a single leakage incident, but this Duracell Procell "Professional" battery did.
Also a side note to whoever read this from Tek, can you spend one or two more dollars on a better battery brand? I paid $150 to calibrate a handheld multimeter, and I certainly don't want to get this.
