Author Topic: Recover files from android built in memory  (Read 1774 times)
Offline sony mavicaTopic starter
« on: June 20, 2018, 11:32:41 pm »
ive used Recuva before and its works great to recover files from sd card or flash stick hdd ect but
but my phones built in memory does not show up in my computer it only shows up as a device so in Recuva i can't select it
what can i do i need to get back 4 photos back if possible i deleted by mistake
MORE POWER!
Offline Halcyon
  • Global Moderator
Re: Recover files from android built in memory
« Reply #1 on: June 21, 2018, 12:50:24 am »
It's going to be quite difficult to do at home without specialised tools and skill. Most phones don't show up as drives in Windows and even if they do, it's not a guarantee that any recovery software will have direct access to it like a normal drive in order to read the unallocated data.
It also depends on the type of phone you have, whether the data was encrypted, how long ago you deleted the files, etc...
Specialised tools exist to dump the entire contents of a phone's memory to a file, but those are *very* expensive and depending on the phone, only accessible to Government agencies.
« Last Edit: June 21, 2018, 12:52:14 am by Halcyon »
The following users thanked this post: sony mavica
Offline amyk
« Reply #2 on: June 21, 2018, 02:33:21 am »
If it's a Mediatek you can find it for free: SPFlashTool. Great way to backup everything bit-for-bit and restore from a brick, if you're into ROM modding and such.
I haven't worked with any other manufacturers' but I imagine they have similar "factory tools" that you might be able to find online.
If you only want to recover a small amount and have a rooted phone, then dd will work to get an image you can then work on. Most importantly, stop using it until you get that disk image --- or your chances of the data not being overwritten will continue decreasing.
Offline Halcyon
  • Global Moderator
« Reply #3 on: June 21, 2018, 09:44:47 am »
Most don't. If you have an Apple product, they'll just tell you to use iCloud. All the big Android brands will tell you a similar story (use Google Drive, Dropbox etc...) to back up your data. The cheaper Android's are quite easy* to get entire memory dumps from, you might even be able to do this via ADB commands.
For phones like Samsung even uploading a custom boot loader can trip the Knox lock rendering your manufacturer's warranty void and inability to use Samsung Knox features like secure payments etc...
For newish iPhones (from memory, iPhone 5 onwards), they encrypt data by default and each file has its own individual 256-bit AES encryption key. Once a file is "deleted" that key is destroyed which renders that file completely unreadable and unrecoverable. The IOS Security Guide is a good read if you wanted to learn more.
* "Easy" as in inexpensive and simple for a technically-minded user, not "easy" in that any average user would be able to do it.
