Author Topic: Reduced capacity on Sandisk MicroSD cards  (Read 24858 times)
Offline DeltaTopic starter
« on: November 04, 2016, 01:37:00 pm »
I've been using 32GB Sandisk cards (Sandisk Ultra microSDHC UHS-I, class 10, to be precise) for my Raspberry Pi projects, and once I had everything set up nicely I took a backup image of the SD card and use that same image for each new project.
I had been buying the cards as and when needed off-the-shelf in my local Tesco (large supermarket chain) for £14 a pop, and hadn't had any problems.
Then I bought one from eBay (just under a tenner) from an "Official Sandisk eBay partner" in the UK.  I noticed the packaging was slightly different, which raised suspicions, and then when I tried to write the image to the card I found its capacity was 810MB less than the cards I had been using!  >:(
I opened I request on eBay, and fired off a message to the seller explaining that this item was a fake.
Next time I was in the supermarket, I bought a "proper" card, and the packaging seemed normal (the same as previous good cards bought there), yet when I got it home - exactly the same! 810MB smaller than the old cards!
So either Sandisk themselves have reduced the capacity, or fakes have found their way into the mainstream supply lines...
(I've shrunk my image so I can use these new cards, but I'm still a bit perplexed and pissed off with the whole thing)
Online kripton2035
Re: Reduced capacity on Sandisk MicroSD cards
« Reply #1 on: November 04, 2016, 01:44:16 pm »
IMHO your supermarket also bought fakes ...
Offline hans
« Reply #2 on: November 04, 2016, 02:38:35 pm »
https://dashcamtalk.com/forum/threads/two-32gb-sd-cards-different-capacities-after-formatting.11690/
One reason is that during a low-level format, all the sectors on the card are examined. If any are "bad", then they are marked as bad and are unusable--thus, reducing the amount of available capacity.
That could be a logical explanation. Still doesn't take away the fact that a new card should be 100% rated capacity and not have bad sectors affect the capacity in orders of magnitude like this.
Offline rstofer
« Reply #3 on: November 04, 2016, 02:38:54 pm »
Have you checked for a hidden partition?  Maybe try fdisk?
« Reply #4 on: November 04, 2016, 02:52:50 pm »
I thought then when you wrote an image to a card, you are working at a level lower than the partition table, so this couldn't be an issue?  (For example, my image contains two separate partitions, so the image must incorporate the partition table)
Online nfmax
« Reply #5 on: November 04, 2016, 02:57:53 pm »
In my experience the exact capacity of flash thumb drives and SD cards is variable, even from new. The flash devices used aren't perfect and they expect a few bad blocks, which are mapped out by the device firmware. The stated capacity is the maximum value. On the other hand SSD drives seem to state the minimum capacity, keeping their spare blocks in reserve. As they are higher performance devices, they tend to have extra blocks dedicated to buffereing and caching anyway.
Of course there are fakes, which may have sizes bearing no relation at all to the stated capacity
Offline rstofer
« Reply #6 on: November 04, 2016, 03:37:24 pm »
That's true when using 'dd' but I'm not familiar with the program you seem to be using.
I just looked at an fdsik of an SD card and when I use 'p' to print the partition table, I get a LOT of information on the physical disk size.  It might be fun to compare two 'identical' SD cards and see what shows up.
My 8GB card shows 7,948,206,080 bytes or 15,523,840 sectors of 512 bytes.  fdisk shows this as 7.4 GiB which is short of even the disk industry's opinion on the size of a gigabyte.
You are right about /dev/sdc being the entire SD card.   My only experience with writing images to drives is via 'dd'.  I do a lot of that kind of thing when I make CF images of IBM1130 drives, a completely unintelligible file system as far as a PC is concerned.  But as long as I have the image in a file, 'dd' will write it.
« Last Edit: November 04, 2016, 03:42:42 pm by rstofer »
« Reply #7 on: November 04, 2016, 03:45:18 pm »
I'm using "Disks", the Gnome disk utility.  I'd hazard a guess that it probably uses
dd to do its stuff.
As I've now had two cards that were both 810MB too small, I think it's too much of a coincidence to be caused by random bad blocks / flash cells...
I might contact Sandisk to see what they say...
Offline Ampera
    • Ampera's Forums
« Reply #8 on: November 04, 2016, 03:49:49 pm »
I rarely use FDisk unless I am working with MS-DOS on an 80486. GParted is honestly the only functioning partition manager. I don't think there is a partition it CAN'T manage (Except Windows Dynamic Volumes, the bane of my bloody existence).
I've often seen stuff like this where I can have a 1TB drive, and get 9XX of storage on it, it's confusing but it has to do with drive formats and allocation and whatever it is.
I forget who I am sometimes, but then I remember that it's probably not worth remembering.
EEVBlog IRC Admin - Join us on irc.austnet.org #eevblog
« Reply #9 on: November 04, 2016, 03:58:09 pm »
Here's a brand new card straight out the packet from eBay.  It is 810MB too small to take the original image,
:~$ sudo fdisk -l /dev/sdc
Disk /dev/sdc: 29 GiB, 31104958464 bytes, 60751872 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x00000000
Device     Boot Start      End  Sectors Size Id Type
/dev/sdc1        8192 60751871 60743680  29G  c W95 FAT32 (LBA)
Unfortunately I don't have any of the original "good" cards lying around.  I'll see if can mount the image and get any info from that...
« Reply #10 on: November 04, 2016, 04:03:07 pm »
Here is the original image, mounted as a device...
Disk /dev/loop0: 29.7 GiB, 31914983424 bytes, 62333952 sectors
Disklabel type: dos
Disk identifier: 0x5d98613b
/dev/loop0p1 *      8192   124927   116736   57M  e W95 FAT16 (LBA)
/dev/loop0p2      124928 62332927 62208000 29.7G 83 Linux
Offline mtdoc
« Reply #11 on: November 04, 2016, 04:52:12 pm »
An excellent tool for checking the integrity/authenticity of SD cards (or thumb drives) is H2testw
The following users thanked this post: Delta
Offline RGB255_0_0
« Reply #12 on: November 04, 2016, 05:14:54 pm »
I have a 32GB Sandisk uSD from about 4 years ago and it's 31,914,983,424.
Perhaps Sandisk have shaved off a few costs. Or there's a trojan in their supply line
Your toaster just set fire to an African child over TCP.
Offline suicidaleggroll
« Reply #13 on: November 04, 2016, 05:41:31 pm »
I have a 32 GB Sandisk Ultra uSD from a few years ago, it's 31,914,983,424 as well.
« Reply #14 on: November 04, 2016, 06:29:48 pm »
I've just ran the Linux version of that utility, and the reported capacity is genuine.  That's something at least...
  Data OK: 28.96 GB (60727232 sectors)
Data LOST: 0.00 Byte (0 sectors)
       Corrupted: 0.00 Byte (0 sectors)
Slightly changed: 0.00 Byte (0 sectors)
     Overwritten: 0.00 Byte (0 sectors)
Average reading speed: 31.40 MB/s
I'm still intrigued as to the why the capacity has been reduced; and whether these cards are genuine or not...
If anyone buys a new Sandisk Ultra MicroSD card, please check its capacity and post here!
« Reply #15 on: November 04, 2016, 06:36:44 pm »
They probably changed supplier of the raw memories or the controller, and the new supplier is giving a smaller size flash, so they have to shave off near 1G to handle the spare cells needed for wear levelling, a wear level table, and probably a small chunk of flash to store the microcontroller on the unit firmware.
Offline C
« Reply #16 on: November 04, 2016, 06:42:38 pm »
DD
If you are working with sectors, what happens when you read a bad sector, go to write good data in a bad sector.
At this level, you are below the bad sector information that a file system has. If you change where data is written then you are out of sync with file system.
To clone you need a ZERO error read followed by a ZERO error write by DD.
 FDisk & GParted report the start and end blocks for a partition there is no separation of good blocks vs bad blocks.
And at some point hidden replacement sectors will be used up.
Offline CJay
« Reply #17 on: November 04, 2016, 11:05:52 pm »
Dynamic volumes are fairly easy to deal with but there's no easy official way to do some things.
The lack of capacity on a 1TB drive is also to do with the drive manufacturers 'redefining' the GB
Offline Monkeh
« Reply #18 on: November 05, 2016, 02:39:55 am »
Drive manufacturers are using the correct units. 'everybody' (that is: Microsoft) uses the wrong units.
Offline CJay
« Reply #19 on: November 05, 2016, 08:53:56 am »
True, but the only place I've seen GiB used on a PC was on a fairly recent Linux distro, Apple and pretty much every hardware manufacturer who isn't in the storage media business use GB to mean GiB, MS are far from the only abuser.
Offline Kilrah
« Reply #20 on: November 05, 2016, 09:07:52 am »
Apple actually uses GiB, but label it as GB to avoid confusion.
Those differences also apply to hard drives, friend had 2 4TB drives of the same manufacturer but different "variant" and one had 13GB less.
Offline Monkeh
« Reply #21 on: November 05, 2016, 10:34:56 am »
Errr.. no, they don't.
Offline Kilrah
« Reply #22 on: November 05, 2016, 10:44:01 am »
« Last Edit: November 05, 2016, 10:46:30 am by Kilrah »
Offline Monkeh
« Reply #23 on: November 05, 2016, 10:50:11 am »
Notice how Windows says '228GB' (ignoring your locale issues), and OS X says '245.21GB'. And how the real capacity is 245,202,157,568 bytes.
Also: https://support.apple.com/en-us/HT201402
Storage device manufacturers measure capacity using the decimal system (base 10), so 1 gigabyte (GB) is calculated as exactly 1,000,000,000 bytes.
<snip>
In Mac OS X v10.6 and later, storage capacity is displayed as per product specifications using the decimal system (base 10). A 200 GB drive shows 200 GB capacity
Offline Kilrah
« Reply #24 on: November 05, 2016, 11:26:32 am »
Yeah, got GiB and GB swapped again.
Shows how stupid the whole thing is.
