Author Topic: reference design or starting from scratch  (Read 508 times)
Offline rwDDDTopic starter
« on: March 25, 2026, 08:54:37 am »
hi all :-[
I’ve been thinking about how different everyone’s workflow is. When you start a new project (work or DIY), do you actually build the schematic from the ground up, or just 'Frankenstein' a bunch of reference designs together?
I used to be a hardware dev at a drone countermeasure startup. Honestly? From the day I joined until I left, I barely touched a blank schematic. The original design was total garbage |O.super inefficient and buggy,but nobody had the guts to start over.
We just kept patching the same mess because 'it works (barely) and we have a deadline.'
Is this just the industry standard now?
I’m curious—how many of you guys actually design from first principles anymore
Offline Nominal Animal
Re: reference design or starting from scratch
« Reply #1 on: March 26, 2026, 05:51:48 pm »
I only do hobbyist schematics, but the way I solved this during my 30+ years of paid software development in a dozen different programming languages might be useful here too (because I find myself doing the same with my hobbyist schematics also).
I keep a library of commented, executable pluripotent algorithm implementations, that I adapt instead of copy-paste.  I trim off all the unneeded features, and optimize the rest, and only then integrate to the overall design.  The schematic/PCB equivalent would be a subsystem, perhaps a DC-DC power supply, a transceiver for some high-speed bus, the verified-working way to connect some specific MCU/SoC to DRAM/SDRAM, and so on.  I always have a README file describing the design choices and limitations, and since many of my algorithms involve math, a PDF with its source deriving the math expressions used in the code.  I believe that for schematics, you'd very likely need PCB layout snippets, perhaps for different numbers of layers too.
This is neither "build the schematic from the ground up", nor "Frankenstein a bunch of reference designs together".  It is something very clearly in between; more like proper integration of well-understood parts than either one.  But note that the adaptation part is still quite a bit of work, and is absolutely crucial so that you don't fall into the Frankenstein copy-paste hell.  Fortunately, my own experience shows that it is possible to learn to do; you don't need any specific innate ability to be able to do that.
What I do not know is whether this can be done in the short timespans allowed nowadays for such work.
Offline ftg
    • ftg's RF hax paeg
« Reply #2 on: March 27, 2026, 10:16:17 am »
At work we have a catalog of existing, proven design blocks, so for some DC-DC I can sometimes find something that is known to work and the parts can be sourced.
For hobby use I have my own library of building blocks and parts.
But unless I'm making a derivate of some existing project of mine, it always starts on a blank schematic sheet.
Offline nctnico
« Reply #3 on: March 28, 2026, 12:41:54 am »
For a more complex designs (think SoC + DDR + power management) I like to use the schematics for a reference design as a starter. Sometimes just to copy the symbols and footprints if they are any good. A demo board rarely suits my needs though so I quickly move to doing a custom design. I'm currently in the process of evaluating a new-to-me FPGA and I'm creating a custom designed dev / test board. Typically doing this reveals some areas where more attention is needed so in the long run it prevents doing a respin of the final product.
