Author Topic: Return of 502- Bad gateway Error  (Read 58331 times)
Offline alm
Re: Return of 502- Bad gateway Error
« Reply #125 on: July 22, 2017, 09:37:08 am »
Probably caching/session related, rather than browser/OS.
The following users thanked this post: not1xor1
Offline not1xor1
« Reply #126 on: July 22, 2017, 09:51:13 am »
yes... reloading the page via F5 solved the problem in firefox  :-+
Offline richnormand
« Reply #127 on: July 22, 2017, 02:59:47 pm »
Quote from: ebastler on Yesterday at 04:29:42 PM
Mate, this error has nothing to do with your computer. It's the server which has problems. No need for you to reboot or fiddle around otherwise.
You are right.
HTTP error codes 5xx are server side errors. Not client side.
You are both right of course. The original 502 gateway error is server side.
However since my main computer was always showing the error but simultaneously my laptop did not have issues both connected to the forum at the same time from the same cable modem via my router obviously something was different between the two computer. Cleaning cookies and cache on the machine cleared it. I assume my Chrome browser had the initial 502 page in its cache...
Has not come back yet. Next time I'll see if that is reproducible.
« Last Edit: July 22, 2017, 03:02:37 pm by richnormand »
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
Offline tablatronix
« Reply #128 on: July 22, 2017, 03:05:22 pm »
heh, this is a server side issue and a problem with resources, not something clients are doing. There is nothing you can do to workaround it.
Most likely a bad configuration relating to sql timeouts and buffer sizes, or max_connections being too small, or a memory leak in sql or forum code most likely. I am guessing config , since this issue arises with growth and traffic.
« Last Edit: July 22, 2017, 03:16:24 pm by tablatronix »
Offline StillTrying
  • Country: Broken Britain
« Reply #129 on: July 22, 2017, 05:45:02 pm »
It starts off as a temporary server problem, but then becomes a bigger problem - for most users, the way the 502 page is cached.
I saw very few 502s yesterday, but tried to capture some of their headers, to me 304 seemed right, but 14400 seemed wrong, but that could very easily be because I had no idea what I was doing!
traffic.
I usually have the main index page open in another tab, so have been looking at the number of guests and users when I see some 502s, very roughly, so far the 502s seem to appear when the number of guests and users is low-ish rather than high-ish.
Offline alm
« Reply #130 on: July 22, 2017, 05:54:26 pm »
What is the cause and what is the effect? Could it be that many of the guests (some of which bots) stop trying if they see errors popping up? Like a reasonable person would do, instead of some of you addicts ;).
Offline Electro Detective
« Reply #131 on: July 23, 2017, 01:10:28 am »
I shut down ALL page/s when the 502 appears and try the site again later
Pumping the F5 button and various reload/clear/refresh force tricks  :horse:  >:( :horse: isn't doing the EEVblog server or boss Dave any favors,
especially whilst trying to sort itself out, AND keep up with the extra  'addicts'  demand  |O
« Last Edit: July 23, 2017, 01:12:23 am by Electro Detective »
Offline MarkS
« Reply #132 on: July 23, 2017, 01:19:04 am »
Off to take a hit of "Projects, Designs and Technical Stuff"...
« Reply #133 on: July 23, 2017, 01:24:30 am »
Nor is having a forum that was basically unusable for ~3hrs yesterday.
Online #'s dropped right away as most couldn't be bothered with the BS.
Maybe the new RAM that was installed a few weeks back is crook or there's a virus in the server as up until a week or two back the forums been better than ever.
Avid Rabid Hobbyist
Offline StillTrying
« Reply #134 on: July 23, 2017, 10:05:28 am »
Would your ~3hrs happen to be very close to 4hrs?
« Reply #135 on: July 23, 2017, 10:12:07 am »
It was shite for most of yesterday afternoon but worst from ~3pm until just after 6 NZT.
The post list on the main page just showed a few posts in that time, some were mine after bashing the shite out of F5.  :-BROKE
Avid Rabid Hobbyist
Offline StillTrying
« Reply #136 on: July 23, 2017, 10:50:19 am »
On the few browsers I've tried, ctrl-reload or ctrl-refresh always gets passed the caching, (I don't know about ctrl-F5) often giving just another 502! - so wait a bit before trying that thread again.
I think if all 1200 guests and 250 users were doing that it would slow down the recovery, so don't tell anyone. :)
Offline pknoe3lh
  • Country: at
  • Trust me I'm an engineer
    • My Homepage
« Reply #137 on: July 24, 2017, 09:57:42 am »
got some 502 before .....
Now its time for more information:
http://rsgiveaway.knoebel.at/loadtime.php
I wrote an Cornjob which checks the side every 1 Minute.
It also shows users and guests and should also detect 502 ;-)
The link shows a graph with the captured data.
« Reply #138 on: July 24, 2017, 10:00:16 am »
Killa performance in Kangaroo Central today  :-+
boss Dave has pumped server with Virtual Adrenaline software?   :o
Offline Gary350z
« Reply #139 on: July 24, 2017, 11:07:35 am »
No 502's on Chrome or IE for about 2 days.  :)
Previous 2 days the forum was unusable on any browser.
Offline pknoe3lh
  • Country: at
    • My Homepage
« Reply #140 on: July 24, 2017, 11:17:48 am »
Even though clearing my browser cache sometimes seems to resolve the issue it definitely doesn't always. So, for that reason alone I am prepared to believe those who comment and seem to know, this is ultimately a server problem. I hope we get some clarity about the issue soon so this speculation can be put to rest. At least for now.
Maybe if you get an 502 check with my graph if it is correlated ;-)
Offline ebastler
« Reply #141 on: July 24, 2017, 02:35:26 pm »
Your graph is lacking labels or units on the time axis, which makes it difficult to correlate anything. Could you add labels?
Offline PA0PBZ
« Reply #142 on: July 24, 2017, 02:58:13 pm »
Point your mouse at the loadtime line.
Offline nugglix
« Reply #143 on: July 24, 2017, 03:00:21 pm »
 :palm:
Doesn't help much, I'd say.
Offline pknoe3lh
  • Country: at
    • My Homepage
« Reply #144 on: July 24, 2017, 03:17:46 pm »
UPDATE:
I'm using google charts .. they should handle all the front end ... but yes i tried 10 different things no luck ...
The only work around i found was to use the Tooltip!
After some time (1 Day) the grid lines should be showing up.. just not working under one day  |O |O |O
The following users thanked this post: ebastler
Offline ebastler
« Reply #145 on: July 24, 2017, 09:21:22 pm »
UPDATE:
Thanks, the tool tip does help! The preliminary conclusion from your data seems to be that inordinate load times (and hence probably 502 errors as well?) are not correlated with an unusually high number of users?
Offline eugenenine
« Reply #146 on: July 24, 2017, 10:22:59 pm »
somebody spank that gateway already
Offline DG41WV
  • Country: lk
« Reply #147 on: July 25, 2017, 12:51:25 am »
F5 worked for me.
windows 8.1                Firefox 54.0.1
Offline linux-works
    • netstuff
« Reply #148 on: July 25, 2017, 06:02:12 am »
or a memory leak
they dont use liquid memory anymore.
so, thats not it.
Offline pknoe3lh
  • Country: at
    • My Homepage
« Reply #149 on: July 25, 2017, 09:47:42 am »
Detected some 502 2 hour ago ...  |O
did some have problems?
