Author Topic: RF leakage?  (Read 2167 times)
Offline rexxarTopic starter
    • Forever Tinkering
RF leakage?
« on: June 14, 2014, 05:38:34 pm »
We use RFID pads at work to check in/out items, and on one the SMA(?) connector is broken and the inner conductor is exposed. This pad seems to have a hard time detecting the RFID tags, so I wonder if maybe the RF is leaking out and coming into the tranciever at a lower level than normal?
Offline T3sl4co1l
    • Seven Transistor Labs
Re: RF leakage?
« Reply #1 on: June 14, 2014, 05:44:30 pm »
Probably a combination of reflected energy (the partially-open cable looks like an open circuit, bouncing energy back to the source) and radiated loss (once it gets outside the cable, it can go anywhere -- is there any sensitivity near the cable?).
Seven Transistor Labs, LLC
Re: RF leakage?
« Reply #2 on: June 14, 2014, 05:48:42 pm »
Broken connection to the internal antenna coil then, so that the power transmitted to power the tag is much reduced. This also compounds in having a high SWR on transmit which then reduces the sensitivity of the receiver as well.
