Hi. This is what
I do. Firstly, '
SlverSolder' is correct, about photographing/scanning at a reasonable
resolution first. 'Photos' like '.jpg' etc are obviously
Raster Images, where zooming in only results in
images with blurry ill-defined edges, where you
need/want detailed
Vector images/files, which can take
a long time to create, as you have found out! Fortunately, there is
specialized software that will convert
such Raster images to editable Vector files, like... '
.ai', or '
.svg' etc. The best one I've ever
used/use, is
called "
Vector-Magic". I use the Desktop version. (Not the online one). Now it's not free/cheap, but all I
can say is that...well... you can 'find' it easy enough... Nuff-Said...
Ok, for example, I looked at the '
.pdf' file that
you attached. Obviously that's after you did all your work
in re-creating a Vector file of the board, before including it inside that .pdf... What
I DID, was to screen-
capture that, and save it as a '
.png' file,
DELIBERATELY, to re-create it as a rough Raster file, like so...
![](https://i.imgur.com/OShuaBN.png)
It
LOOKS ok, but zooming in will reveal the defects and pixelations!
I ran that image through "Vector-Magic", (there are many user selectable options), and re-saved it as an
.ai', and an '
.svg', and also as a '
pdf' just so I could display it here! See my '
attachment' below which
at least indicates that it consists of a new editable Vector file, which has saved you 98% of your work!!
You could edit out the components/text from the 'Traces' and keep them on separate layers.
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/xcheesy.gif.pagespeed.ic.KPzuH4J-TG.png)
I can't recommend that software enough. Maybe 'PM' me if you have a hard time...
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif.pagespeed.ce._JElyJQqdB.gif)
P.S. Can you see the 'attachment'?... I've not used that feature here before....
