Author Topic: SMD Resistor Markings to disappear!  (Read 11894 times)
Offline nicknailsTopic starter
« on: April 14, 2013, 10:35:09 pm »
Uh oh, looks like Yageo announced that it's going to stop putting codes on their SMD resistors.  I wonder if other companies will follow suit.  Personally, I think it's going to suck.  It'll make it a lot harder to troubleshoot.
http://www.soselectronic.com/?str=1265
Offline c4757p
  • adieu
Re: SMD Resistor Markings to disappear!
« Reply #1 on: April 14, 2013, 10:46:15 pm »
Figured this was coming. Resistors are pretty much the only SMD part left (except large ICs) that are still labeled with anything somewhat useful.
Armageddon
  • Guest
« Reply #2 on: April 14, 2013, 10:48:00 pm »
This can be a big problem, at least for me.  |O
I hope that the rest of the manufacturers do not take the same decision.
« Last Edit: April 14, 2013, 10:50:53 pm by Armageddon »
Offline c4757p
  • adieu
« Reply #3 on: April 14, 2013, 10:56:37 pm »
Sadly I'm sure they will. It's not like any of their big customers are really going to care, and if they can eliminate an entire step of the production process the bean counters will ejaculate.
Offline BiOzZ
« Reply #4 on: April 15, 2013, 01:17:49 am »
not shocking ... when you can put probes on your pick and place and also verify there value is correct ... but it was not much of a problem with caps it wont be a real problem with resistors
tho i fear were getting to the point where you can no longer preform part harvesting :/ a LARGE chunk of my part box is verified components taken off dumpster appliances!
what really depresses me is my kids wont get to find the joy of playing with CRT flyback transformers   :--
My one regret in life is learning to speak English on the internet ...
Offline c4757p
  • adieu
« Reply #5 on: April 15, 2013, 01:19:33 am »
Do you seriously harvest SMD resistors??
Offline BravoV
  • +++ ATH1
« Reply #6 on: April 15, 2013, 01:23:35 am »
I do, especially < 1 ohm and even better high wattage ones, these bugger are quite pricey if bought new.
Offline BiOzZ
« Reply #7 on: April 15, 2013, 01:42:16 am »
yeah ... nothing a cheap heatgun and a metal card cant do .. just heat up the pcb and scrape them off
SMD resistors and caps are just as useful as threw hole for me when it comes to second hand parts ... you can for the most part solder them right between pads on perf boards!
Offline mrflibble
« Reply #8 on: April 15, 2013, 01:44:54 am »
Please don't do that. Tea hot!  :-DD
Offline c4757p
  • adieu
« Reply #9 on: April 15, 2013, 01:49:19 am »
Huh?
Offline mrflibble
« Reply #10 on: April 15, 2013, 01:53:16 am »
I was just drinking some hot tea when I read your remark concerning ejaculating bean counters. :P
Offline NiHaoMike
    • Facebook Page
« Reply #11 on: April 15, 2013, 02:39:02 am »
A lot of SMD resistors already don't have markings. But that's easily solved with a multimeter. (If there's a fault that causes the resistor to change value, it most likely would have obliterated any markings anyways.)
BTW, I have also seen unmarked through hole resistors. I think they're production errors but then why weren't they rejected?
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
Offline nanofrog
« Reply #12 on: April 15, 2013, 03:36:04 am »
If I had to guess (assuming production errors), they were slated for destruction, but an enterprising exec or employee "slipped them out of the back door" instead. Money coming in instead of sending them off for recycling would certainly look better on paper, and for an enterprising employee (unbeknownst to their employer), an additional side income.
Offline gxti
« Reply #13 on: April 15, 2013, 04:53:37 am »
Those aren't the cheapies that are being discussed here though. Larger, more expensive resistors would still have markings. The relative cost of marking a 50 cent part is trivial, but the cost for a sub-cent part is much more significant.
You're a looney!
Offline Neilm
« Reply #14 on: April 15, 2013, 05:39:29 pm »
I have seen through hole resistors that were deliberately not marked. They were designed for potting or immersing in oil so they don't want chemical contamination. After all, if you have potted it you can't read the marking anyway
Neil
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
« Reply #15 on: April 15, 2013, 06:43:04 pm »
SMD test tweezers look like a good thing, luckily they came with my LCR meter. Might take a while to get things together on the bench though if i sneeze though.
