Over the last 5 years, I've built approx 25-30 machines, all of them use an SSD for the OS (usually there is one or more spinning disks for bulk storage, but sometimes the SSD is the only drive in the system, ie: laptops). Of those 25-30, I'd say somewhere around 15-20 of them use Intel SSDs, about 5 Crucial, plus a Mushkin, an OCZ, and a Sandisk. The majority of them run Linux, but there are 3-4 Windows systems in there too. The vast majority run 24/7. There is the occasional reboot for updates, but other than that they're always running. Some are big powerful rackmount servers, most are workstations, and a handful are laptops or embedded systems (fit-PC).
In all of that time with all of those machines, I have experienced precisely zero SSD failures (zero failures of any kind for that matter, apart from one LSI RAID card that started complaining, so I RMA'd it "just in case"). The one time I thought a problem might be due to a bad SSD, it turned out to be an incompatibility with the BIOS used on an old Dell laptop. The worst I've seen is that sometimes the BIOS posts before the SSD is available and you get the "no disk found" error, but a quick Ctrl+Alt+Del brings it right up.
So I'm afraid I can't really help, but I can say that two Intel SSD failures in as many years is far from normal in my experience.
