Useless gimmick, like the small solar chargers it has a LiIon battery inside, otherwise they'll have a 100% return rate.
The BioLite CampStove uses a small internal fan to create airflow, which, in conjunction with our uniquely designed fuel chamber, creates an ultra-efficient fire with highly improved combustion. The heat generated by the fire is converted into electricity in our Power Module which automatically recharges the lithium ion battery powering the fan. Surplus electricity powers a USB outlet allowing you to charge small electronic devices.
Can't find much about the power but it says:
iPhone 4S (2G): 20 minutes of charging provides 60 minutes of talk time. Charging times vary by device and by strength of fire.
Charging times vary by device, as well as by the strength of the fire and other variables like outside temperature. For an Apple iPhone 4S (2G), 20 minutes of charging with a strong fire can provide you with 60 minutes of talk time.
As that iPhone has 14h talk time on 2G it means you'll need 14 times more =
4.66 hours of "strong fire" to charge your phone (note the language, it isn't clear if you also use the Li battery from inside the stove during that time!).
You get quite a few charges from one of those "power packs", even a 10-11+Ah will be much smaller/lighter/cheaper than this stove (even if you include some other decent reliable stove).
Plus fan+liion battery+fire going for tens of hours (if you want to get multiple charges, as you get from a big power pack) don't go well together.
