Author Topic: Suggestions for TFT monitor 23 - 24 "  (Read 10408 times)
Offline Kiriakos-GRTopic starter
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
Re: Suggestions for TFT monitor 23 - 24 "
« Reply #25 on: January 23, 2011, 02:33:55 am »
About contrast and brightness , I have set them 70 & 30 .
About the resolution I am a bit confused  of what to use at its need.
I am happy that I found on the menu an setting that the monitor becomes 4:3 , and at 1024x768 the resolution that I was using on my 19" CRT , makes everything to look as with the CRT .. or very close enough. ( Yes I have black bars at right and left.. )
Now I am looking for some short of software that will divide my screen in windows ,
so all my main software applications to look as 4:3 , and the extra space to be for secondary needs.
That's what i have in my mind right now.
About the calibration , thanks for the advices, I will look at it as last .
The DELL came almost calibrated .
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #26 on: January 23, 2011, 02:43:18 am »
man! you are the one who want to stick to the 80's. well ok i understand that. and you are the first man i heard wanting the such a SplitView and WinSplit software. not a true split though, just saving you a couple of click i think, i prefer the manual method, and all the 16:9 fullscreen. its just now i kinda needing the multiple monitor feature that comes with my previous display card, just a click on the tasktray, then i got a brand new fresh empty desktop to work on. i always keep the taskbar stacked heavily with multiple app. luckily there is "Minimized All Windows" aka "Show Desktop" and IE8 got "new tab" instead of "new window".
thats what most people without the calibrator always say. but when they got it, they wil say, oooh f*ck! my screen goes pink! :D
« Last Edit: January 23, 2011, 02:55:39 am by shafri »
  • Country: gr
  • User is banned.
« Reply #27 on: January 23, 2011, 03:19:04 am »
 :D  :D  :D  :D
70s was the best time , all the older ones knows that best ..  ;)
Thanks for the tips..
Offline PetrosA
« Reply #28 on: January 23, 2011, 07:28:25 pm »
 :D  :D  :D  :D
Aman... ;)
LCD monitors are like digital cameras in reverse - there is a definite number of pixels in the display as there is a definite number of photosensors in a sensor. You can take a photo at a lower resolution in some cameras but the image will suffer because either a number of pixels will be binned together to form a new pixel (downsizing) or in software pixel information will be interpolated to form new pixels (upsizing). Either way the image will not be what the sensor was designed to capture.
Your monitor's native resolution (the only one that works at a 1:1 ratio with your graphics card) is 1920x1080. That is the only resolution that will give you a sharp image without ghosting and artifacts. If text is too small at this resolution, you can change that in Windows settings. It may take some time getting used to, but you'll get used to it :)
I miss my home I miss my porch, porch
Online Zero999
  • 0999
« Reply #29 on: January 23, 2011, 07:39:07 pm »
Yes, use the native resolution (1920x1080) and increase the font settings if it's too small.
Offline jahonen
« Reply #30 on: January 23, 2011, 07:41:56 pm »
I certainly would not use any other resolution on a LCD monitor than its native resolution. Resolution difference is not large enough to allow decent scaling. Of course there is picture but it looks horrible in any other input resolution. I have Eizo S2410W (1920x1200 resolution, 24", S-PVA) for ?5 years now, and still going strong. I'm satisfied if it lasts at least for another five.
Regards,
Janne
Offline Longhair
« Reply #31 on: January 23, 2011, 08:08:53 pm »
How does a person know if the monitor is calibrated or not without a calibrator?
I have 2 of the same model monitors set to the same exact settings in the menu however, the color is different between the two  :-X
Online Mechatrommer
  • Country: my
« Reply #32 on: January 23, 2011, 11:18:19 pm »
get another person's monitor with calibrator and compare it side by side. ;) its like having a mass and you dont know its weight and ask, how do i know this is a 1kg mass? without a scale. another thing to note, monitor will be calibrated every now and then coz the intensity, color will change in time. with spyder there is option to calibrate your monitor every week, month or 3 months and a warning will popped out saying your calibration is out of date. for me, i will set the calibration to the longest period, coz from experience, there will be only slight shift after months and all i care much is monitor to print consistency.
ps: and another fun thing about colorimeter is, you can spend on a calibrator, and later buy an elcheapo monitor and get it consistent will all who have that calibrator all around the globe. my samsung and chimei look the same! ;)
« Last Edit: January 23, 2011, 11:31:58 pm by shafri »
  • Country: gr
  • User is banned.
« Reply #33 on: January 24, 2011, 05:21:31 am »
I would be the happiest person if at the full resolution the menu of the software like word - photoshop and others did not look that tiny ..
The only wide resolution that works for me so far, are the 1360-768 , its the most clear about scaling at list.
Yes technically you all are correct , just my blue eyes disagrees with you .   ;)
Online Mechatrommer
  • Country: my
« Reply #34 on: January 24, 2011, 05:53:20 am »
what matters most is that you are happy. if you think you dont need a calibrator, and you'll be happy with that, then by all mean, game all you like! ;)
