Author Topic: Teardown: SAAB electronic heater fan speed controller.  (Read 1322 times)
Offline RefrigeratorTopic starter
  • Country: lt
« on: August 18, 2020, 12:57:39 pm »
While pulling my old crashed SAAB apart i found out that the heater fan speed was controlled electronically instead of a resistor pack.
I thought it was quite modern for a mid 90's car and so i decided to take the module apart and reverse engineer it. But as i traced the circuit out i noticed something strange, that being that there was no freewheeling diode. Weird i thought this module worked with PWM, efficiency and all that right?
Nope it's actually just a huge linear constant current regulator, shame.
There's only one IC inside which is an LM2904 dual op-amp. The muscle is an IRFP054 MOSFET, 60V and 64A continuous at 100oC is quite nice.
At first i thought that i could use this to control the motor on my homemade electric scooter but since it's linear that's not really possible.
But i could definitely use the MOSFET to make a speed controller.  :-+
« Last Edit: August 18, 2020, 01:08:36 pm by Refrigerator »
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
An expert of making MOSFETs explode.
  • Country: lt
Re: Teardown: SAAB electronic heater fan speed controller.
« Reply #1 on: August 18, 2020, 01:07:24 pm »
And a couple more pics.
Offline Dabbot
« Reply #2 on: August 18, 2020, 01:20:33 pm »
Interesting! The values for "R3" and "R3?" are a strange choice. The same could be achieved with 8K2 and 10K.
Maybe double-check that bit?
Edit: On second thought, the 16K5 resistor looks to be hand soldered in. Manually trimmed?
« Last Edit: August 18, 2020, 01:27:23 pm by Dabbot »
  • Country: lt
« Reply #3 on: August 18, 2020, 06:55:53 pm »
I might have read the colors incorrectly, as the resistors are super small and telling the difference between blue and purple was hard.
But i also think it's manually trimmed, kind of weird that they didn't use a trim pot. Perhaps trim pots aren't good enough for this application?  :-//
Offline GlennSprigg
  • Medically retired Tech. Old School / re-learning !
« Reply #4 on: August 20, 2020, 01:42:05 pm »
Yea, I just had flash-backs of 'old' (older) cars...  To keep the 'resistors' cool, the wiring went to a Block with the resistors, mounted
inside the main fan/conditioner unit body, so that the air-flow cooled it!  Was a locating trap for the uninitiated.  :)
Diagonal of 1x1 square = Root-2. Ok.
Diagonal of 1x1x1 cube = Root-3 !!!  Beautiful !!
Offline tom66
« Reply #5 on: August 20, 2020, 03:12:57 pm »
It's interesting that they still went for a linear regulator despite having all of that circuitry there which could have easily implemented PWM.  Perhaps they were worried that PWM would be audible, or possibly visible in the lighting.   I recall the headlights and interior lighting on my Peugeot would dim occasionally when the wipers swiped the window, if the engine was at a low RPM.
On older Opel/Vauxhall vehicles the resistor pack has been known to cause the vehicle to burn down when the thermal fuse does not correctly interrupt power due to a stalled motor condition.  If the fan motor stalls and the fan is set to a low or medium position, the resistor pack has no cooling and begins to get very hot indeed.
« Last Edit: August 20, 2020, 03:15:13 pm by tom66 »
The following users thanked this post: GlennSprigg
  • Country: lt
« Reply #6 on: August 20, 2020, 07:09:00 pm »
The interior lights in my SAAB were PWM controlled and you could hear the slightly audible noise when they dim slowly.
I actually thought this feature was super cool. But then again why not PWM for the fan?
Does switching high currents with PWM have EMI implications?
