It starts crushing nicely... but then hits the rock-hard, rigid chasis and the occupants go ballistic, the vehicle even bounces back and hits them harder.
That is all OK, because the batteries will then catch fire cooking the occupants who can not escape anyway.
Except EV catch fire way slower so chances of escaping are higher and it happens 10+ times rarer (per same number of units) than with ICE vehicles. You don't see ICE vehicles on fire in the news because it happens so often that it's too mundane. Also Cybertruck has manual door release, the same as other Tesla cars.
ICE cars bursting into flames after accidents was so rare in earlier years that we used to sneer at Hollywood movies showing that happening.
Wrecked cars commonly looked like a giant had stepped on them like we might on a tin can, but no sign of fire.
These days, it is so common that it is almost routine.
It seems nobody has connected the dots!
My theory is it is because of the presence of pressurised fuel pipes plus high-capacity fuel pumps.
With old cars, an accident usually stopped the fuel pump so the supply of fuel to help start a fire was much reduced.
Then there are Jeeps, which don't even need the accident, but go "woompf" just sitting in a driveway.
I only ever saw two cars spontaneously "just start to burn" in the old days.
One was my old Austin Tasman, & the other was a early 1980s Peugeot.
In each case, it was a quite gentle, slow process, with plenty of time to remove yourself & valuables from the vehicle.
