Author Topic: Texas Instruments XDS200 USB Debug Probe  (Read 15625 times)
Offline developerRTopic starter
« on: February 28, 2024, 04:11:32 pm »
Hi
I bought this device from RS in the UK believing it was a TI part. I have hardly used it and it has failed during a firmware probe check. So now I am in the position of having a bricked XDS200. RS wont help me as its just over a year old. The actual manufacture is Blackhawk-Dsp / Corelis and they are blanking me. And because I am retired (no company clout anymore) I cannot contact Texas Instruments even via E2E. Its a TI reference design.
I am at a loss what to do. Just proves that RS are box shifters and quite honestly I wish I had bought from AliExpress
Any suggestions?
Offline thm_w
  • Non-expert
Re: Texas Instruments XDS200 USB Debug Probe
« Reply #1 on: February 28, 2024, 11:04:04 pm »
« Reply #2 on: February 29, 2024, 01:01:52 pm »
Nice suggestion but the serial number is logged.
I really cannot understand how RS get away with huge mark ups yet provide zilch technical support. They should have a workshop and the ability to re flash kit as a minimum.
Anyone else feel powerless being outwith a corporate structure?
Offline thm_w
  • Non-expert
« Reply #3 on: February 29, 2024, 10:36:31 pm »
RS logs the serial numbers when they sell them? That would be a surprise.
Can the case be swapped over without breaking any seals.
« Reply #4 on: March 01, 2024, 10:25:26 am »
As part of my support request to RS the serial number was logged. All that I am asking of RS is to put pressure on Blackhawk DSP for a remedy but they dont want to know
Offline thm_w
  • Non-expert
« Reply #5 on: March 01, 2024, 10:14:42 pm »
Yes but you'd be opening a new case for the new probe, which would have no SN associated with it.
Anyway, you can pursue the legal avenue but it might be more work and take longer: https://www.citizensadvice.org.uk/consumer/somethings-gone-wrong-with-a-purchase/return-faulty-goods/
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #6 on: March 02, 2024, 03:30:41 am »
If you have another XDS JTAG debug probe, you can try to re-flash it by following the procedure shown in the URL below - despite it mentions the onboard/embedded Debug Probes, it works for the standalone probe as well.
https://software-dl.ti.com/ccs/esd/documents/xdsdebugprobes/emu_xds200.html#re-flash-the-firmware-of-onboard-xds200-units-
You will have to open your probe for that to work.
« Reply #7 on: March 02, 2024, 04:43:14 pm »
Its beyond reflashing via USB. I have opened the device including the seals.  Its disappointing to find a completely non standard JTAG ? connector. Its a AM1802 inside. Because if I knew the pinout I could use another emulator and reflash. The problems all began when I discovered it didnt work via a usb hub so I was using TI software to probe it. My last resort would be taking a guess on the JTAG pins.
Online rsjsouza
  • Eternally curious
« Reply #8 on: March 02, 2024, 05:07:59 pm »
Read all the links on the reference I sent. One of them has the pinout of the edge connector used by the XDS200's PCB (IIRC), which is similar to the Mezzanine card used in some of the EVMs.
« Last Edit: March 02, 2024, 05:10:06 pm by rsjsouza »
« Reply #9 on: March 02, 2024, 07:44:49 pm »
Hi
appreciate the links but that is for another device. I have the TMDSEMU200-U which has a 16 way samtec connector nothing like any JTAG I have seen before.
I now have a chink of light I have managed to open a support case with TI so hopefully that will bear fruit. That post reflects
on the hub difficulties that I experienced. It is certainly not fit for purpose and and that price a scam.
Thanks and regards
Online rsjsouza
  • Eternally curious
« Reply #10 on: March 03, 2024, 12:04:11 am »
Ok, if you see a connector inside, it is probably the cTI 20-pin connector, a ~15 year old standard for TI processors.
Its pinout (and several others that comprise the TI and ARM JTAG connectors) is shown at:
https://software-dl.ti.com/ccs/esd/documents/xdsdebugprobes/emu_jtag_connectors.html
« Reply #11 on: March 03, 2024, 12:55:56 pm »
Hi
Its certainly not a standard JTAG connector as I have all the adapters for Segger /TI / ARM / SWD and they are 10w 20w and 14w whereas this is a 16w
