I was reffering to the compatibility of the phone and power supply and the phones ability to meet the regulations every time with any USB brick supply, if the USB power supply fails in it's own right then that is nothing to do with the phone. So any properly designed phone will pass EMC regs will pass with any properly designed USB brick. So having to supply a USB brick to meet regs is no excuse for making you buy a USB brick with the phone.
Last time I was in an EMC chamber the first words out of the mouth of the test engineer after we turned it on was: is it on?
It should be two separate devices.
Isn't it one of the original purposes of EMC to "guarantee" you can plug the device into the socket, and any phone into any charger?
But you test every device separately
I expect there is some reference USB PD against it phones are tested the same way as is standardized mains for testing
I
bolded the relevant statements.
First, as opposed to the specifics of phones, consider the general case of any appliance with any appropriate generic power supply.
There are a few cases we can discuss:
1. A specific appliance provided with a specific power supply.
2. A specific appliance provided without a power supply.
3. A power supply tested as a separate product.
Case 1:
A system of some kind is designed and specified. The power supply is chosen for various reasons such as cost, availability, power, EMC levels, other standards, etc. The rest of the system is designed to whatever function it provides. The combination system is tested at an accredited EMC lab. The power supply and the appliance are electrically coupled, and appropriate tests are performed.
Case 2:
A system of some kind is designed and specified. The power supply is left out of the provided system for various reasons. Cost, etc. The system must be powered to operate, so a power supply is used. To the extent possible, the power supply is left out of the EMC tests. Therefore, other variations of the EMC test procedure are used. For instance, in Case 1 the LISN connects to the AC lines of the AC-powered power supply. In this case, the LISN connects to the DC lines between the two. This is a very different EMC situation, typically requiring additional filtering on the DC input of the appliance.
Case 3:
A power supply is designed for generic applications. It is EMC tested with some type of load. However, obviously not all combinations of loads can be tested. For instance, consider that the power supply has a switcher at some frequency. The load may be other switchers and any range of frequencies and draw characteristics, some of which may cause the power supply to have EMC problems that weren't found in the EMC lab.
Simon's statement fails at the term "properly". What defines that? In Europe, it's basically the CE mark. This doesn't mean some particular combination will pass.
Miyuki's statement fails at the term "guarantee". The EMC standards are meant to prevent one system from interfering with another. These systems could be two internal parts, which is where the system test comes in, or two independent systems, which is the purpose of both emissions and immunity testing. In the case of plugging in the power supply, the test is done to some generic loads. However, the specific load of the appliance may be out of the range that a specific power supply was tested to.
In general I have two takeaways:
1. It's a nice idea. There will be unintended consequences.
2. Is this really the biggest issue that could be addressed with e-waste?
