Author Topic: The whole wifi con  (Read 21488 times)
Offline IanMacdonald
    • IWR Consultancy
Re: The whole wifi con
« Reply #100 on: November 22, 2017, 10:06:48 am »
They already do... sort of. A lot of houses are built with foil backed foam insulation board in the walls like this stuff.
If they manage to install a smart meter here (Which will call for an armed escort) then some of that is definitely going in. At least I have an excuse that I was being 'green' by adding insulation, when they lose their spy signal.  :-//
Offline tooki
« Reply #101 on: November 23, 2017, 07:14:27 pm »
If no other devices are using the WiFi spectrum, channel 6 is the most likely to give the best performance but if the air is not empty, 6 will probably suck  ;D
In a totally vacant spectrum, why would 6 perform any better than any other channel? The channel bandwidth is the same for all the channels, afaik.
Online Ice-Tea
    • Freelance Hardware Engineer
« Reply #102 on: November 23, 2017, 08:11:06 pm »
This.
Offline Monkeh
« Reply #103 on: November 23, 2017, 08:33:46 pm »
You may want to check where the channels sit in relation to that.
Offline tooki
« Reply #104 on: November 24, 2017, 06:27:42 am »
Offline borjam
  • EA2EKH
« Reply #105 on: November 24, 2017, 07:08:40 am »
This.
Not all antennas are created equal :) Some are broadband designs that work well regardless of the channel you are using.
Online Ice-Tea
« Reply #106 on: November 24, 2017, 08:42:25 am »
Antennae (and other RF components) do not have flat return loss, insertion loss etc etc. As the middle of the band coincides with channel 6 (wel, rather somewhere between 6 and 11 actually...), this ussually means RF performance is a bit better there...
No need for a source: take any wifi antenna.
Offline borjam
  • EA2EKH
« Reply #107 on: November 24, 2017, 09:14:06 am »
Of course not, but there are broadband antennas with a broader region of low enough return loss, and there are narrow band anntenas.
Unless you are using a narrow band antenna tuned to a certain channel the difference will be negligible.
Online Ice-Tea
« Reply #108 on: November 24, 2017, 09:35:02 am »
The above is a typical wifi antenna. Wouldn't call it negligeable.
Online wraper
  • Country: lv
« Reply #109 on: November 24, 2017, 09:45:14 am »
Intentionally making antenna like this would not even make much sense as it works best at around channel 13. And it actually contradicts to what you said about channels 6 working the best.
Offline borjam
  • EA2EKH
« Reply #110 on: November 24, 2017, 09:53:08 am »
First: Typical antenna, in which context?
Second: RL below 8 dB can be considered quite harmless. Or am I missing anything?
Online Ice-Tea
« Reply #111 on: November 24, 2017, 10:08:23 am »
You'll note I already requalified my statement: "(wel, rather somewhere between 6 and 11 actually...)  ;D
What do you mean? Not sure I understand but lets turn this around: can you show me a wifi antenna that does not have RL dip in the 2.4-2.5GHz band?
Depends on what you call harmless. At 8dB, 15% of your output power is lost. At 20dB (the 'dip') something like 1%.
Online wraper
  • Country: lv
« Reply #112 on: November 24, 2017, 10:37:19 am »
No, if we say like this, then somewhere in between of 12 and 14 :).
Online Ice-Tea
« Reply #113 on: November 24, 2017, 10:45:29 am »
What about this: surely not Channel 1?  :popcorn:
Offline borjam
  • EA2EKH
« Reply #114 on: November 24, 2017, 10:52:59 am »
Which means a loss of .7 dB.
Economists think in percentage terms. RF engineers think in dB terms  :horse:  :box:
(I'm not an engineer myself, but a Physics drop-off, but certainly not an economist at all!).
Attached is the S11 graph of a really narrowband antenna. A HF tuned loop. You must retune even if you are making a 2 KHz change :)
(A MFJ-1788 loop)
« Last Edit: November 24, 2017, 10:56:47 am by borjam »
Online wraper
  • Country: lv
« Reply #115 on: November 24, 2017, 10:53:35 am »
:box: :-DD
Online Ice-Tea
« Reply #116 on: November 24, 2017, 11:16:20 am »
*shrugs* Call it what you want. It's lost.
:box: :-DD
 |O :palm:
Joking aside: not exactly the kind of antenna you'll find in off the shelf wifi equipment.
*waits for wraper to dig up an off the shelf piece of wifi equipment that has this antenna*
Offline borjam
  • EA2EKH
« Reply #117 on: November 24, 2017, 11:35:21 am »
Of course you can find good, reasonable and crappy antennas. I remember some antennas I tested a couple of years ago. Granted, they were cheap despite being attached to an (COUGH!)"N"(COUGH!) (*) connector, and the "radiating element" was just a more or less random piece of wire inside a plastic piece.
I tested 20 of them with a VNA and there were no two equals. But fine, the person who asked me to try them told me the cost was a hefty dollar a piece or so. These antennas were sold as "3G antenna" and they are all part of the same batch. Out of 20 I think that maybe 5 didn't even have a piece of wire inside.
This is more or less the equivalent of the fake ferrite suppressor you find in bottom of the barrel USB cables. Just a cylinder of plastic.
Note for the curious, that awesome VNA is not mine, it's at the University. My own VNA is cheaper than that VNA's calibration kit.
(*) The cough is due to the fact that the connectors were N compatible (you could plug them!) but they were more like a copy of an N connector. The quality of the centre ring was apalling.
