Good old Ohms law is responsible for most of the problems in this article.
You have two power sources:
1) Grid, 112V very low impedance.
2) Solar Inverter, 112V low impedance.
Note, this doesn't work as intended, as the grid has much lower impedance, also add in the losses into the transformer.
So the Solar inverters boost the voltage, say to 113V or even 115V, so current is drawn from the inverter instead.
However, there is a maximum voltage for the street grid, to avoid damage.
So at some point the solar inverters will shut down, and stop outputting power.
So the power companies have choices to make:
1) Limit how many kW of solar is on a particular street transformer. or;
2) Alter the tap on the transformer to output a lower voltage to start with (or just install new transformer anyway.
3) Install a transformer with auto tap changer.
Oh yeah, and likely some of these transformers needed replacing anyway, as too close to being overloaded or just old.
I suspect the US isn't doing themselves any favors by using 110V AC, as the extra losses in cables mean more transformers and less houses on each to even out the load.
As most of these problems exist in other parts of the world, there are solutions:
1) Demand management, digitally broadcast to homes when there is an over/under supply of power in their area. Whatever automatic system is in place can offer to increase/reduce by X kW, requires say fiber optic internet for low latency.
2) Neighborhood battery storage, install batteries to soak up excess power and sell it back at night. Only profitable if not charged utility fees, and the power company don't like that or others making money.
3) Install two separate inverters in houses, so solar/battery power still runs the house in cases of high grid voltage/blackouts. Some power companies don't like off-grid power solutions like this.
Personally I like the Neighborhood battery, it can work well, helps everyone not just those with their own solar/batteries.
Problem is it's not profitable if the power company want full line fees for sending power maybe 200 meters tops, as it's paid twice as in/out and isn't large scale.
Can also be setup as a way to "bank" power, generate excess during the day, get it back at night at the same price.
Could also be wired up to power the entire street to prevent blackouts, just switch the transformer out to prevent backfeed.
