Author Topic: Tinning traces for more current  (Read 32862 times)
Offline PoeTopic starter
« on: July 18, 2012, 09:19:38 pm »
Just watched the EEV blog #314 and noticed the tinned traces intended to increase a trace's current carrying capability.
Since solder has something like ~1/10th the conductivity of copper, how effective would this be?   .
Has anyone looked into this technique?  I've seen it used quite a bit in older boards, but it never made much sense to me.
Offline Bloch
Re: Tinning traces for more current
« Reply #1 on: July 18, 2012, 09:37:45 pm »
I also raised my eyebrows when Dave mentioned it.
Maybe it will even make it worse .... but right now i cant remember there i did read/hear that.
Offline Electr0nicus
  • Country: at
« Reply #2 on: July 18, 2012, 10:43:38 pm »
If you open a pretty standard desktop PC PSU and take a look on the main PCB, you'll see this technique all over the whole board.
The main intention is to reduce cost. 2oz or more copper thickness gets really expensive, as Dave said in the video.
I also don't think, that tinning the traces makes things worse. At least there is more conductive material available, so the resistance will go down  in any case, that's for sure. The only question that arises, is the effectiveness of such tinning, because you wouldn't be able to get a even thickness of tin along the whole trace.
« Last Edit: July 18, 2012, 10:48:42 pm by Electr0nicus »
Offline Bloch
« Reply #3 on: July 18, 2012, 11:03:48 pm »
Yes the resistance will be a little bit lower. Anyone with a good low Z multimeter there want to make some test ?
But that if the track cant get rid off the heat. ? The Tin must act like an heat insulator or do you think it will be better to get rid off the heat ?
« Last Edit: July 18, 2012, 11:05:30 pm by Bloch »
Offline Rufus
« Reply #4 on: July 18, 2012, 11:46:26 pm »
1oz copper is 35um. Putting 0.5mm of tin on a 1oz track would more than halve its resistance.
More surface area, no solder resist, slight protrusion into air flow. I would say dissipation is likely improved slightly.
Online EEVblog
« Reply #5 on: July 18, 2012, 11:54:13 pm »
Correct.
It can't do anything but help reduce the resistance and improve the dissipation (which is now lower thanks to the lower resistance)
Dave.
Online EEVblog
« Reply #6 on: July 19, 2012, 12:06:18 am »
IIRC, copper is about 2-3 times better, not 10 times better.
Dave.
Offline Chasm
« Reply #7 on: July 19, 2012, 01:06:41 am »
The specific resistance (1m*1mm^2) of copper is 0,0178 ohm, tin is 0,1150. Thats a factor of 6,46.
For historic comparison: lead with a specific resistance of 0,2080 is even less condutive (11,68 times compared to copper), so the old Sn60Pb40 solder has a specific resistance of 0,1522 or 8,55 times worse than copper.
Offline amspire
« Reply #8 on: July 19, 2012, 02:41:48 am »
I do not think that the unmasked strips in the power supply were there to allow the solder to reduce resistance.
I think the track's design margin is so low, that they thought they may need to solder a length of copper wire on top of the tracks. That is why they only left a thin strip unmasked, rather then the whole track width.
They obviously decided they could get away with no copper wire, but if I owned the supply, I would add them.
Offline Chasm
« Reply #9 on: July 19, 2012, 07:16:40 am »
Soldering copper wired onto tracks actually works rather well but also has some potential drawbacks. (Say potential vibration problems over time.)
There are also options to embed such wires into or on top of the PCB, but that is rather expensive and thus only used in very high power stuff. (Copper Inlay PCBs)
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #10 on: July 19, 2012, 08:50:24 am »
Resistivity figures from Wikipedia, adjusted to have same exponent
Copper 1.68×10?8
Tin       10.9×10?8
Lead       22×10?8
I've just done some actual measurements - short video uploading now..
Day Job: Mostly LEDs
Online EEVblog
« Reply #11 on: July 19, 2012, 08:53:42 am »
Poop, I was going to do that!  :P
Dave.
Offline Bloch
« Reply #12 on: July 19, 2012, 09:32:49 am »
Thank you for taking time to do that. It will be very interesting info for me at least.
« Reply #13 on: July 19, 2012, 09:41:42 am »
Offline almoehi
« Reply #14 on: July 19, 2012, 09:56:34 am »
Dave.
Yesss!!! Battle of the tear down titans.  ;)
Offline dda
« Reply #15 on: July 19, 2012, 09:59:05 am »
I would have thought that because of its low melting point, solder's conductivity would rise fairly fast as more current passed though it and heated it. But actual measurement is better than talk... time to watch the video.
edit: and of course I'm wrong, resistivity increases with temperature, not conductivity.
« Last Edit: July 19, 2012, 10:07:42 am by dda »
Offline Bloch
« Reply #16 on: July 19, 2012, 10:06:57 am »
Mike a great video as always.
40% improvement is not bad i must admit  ;)
That about long term use. I think about bad soldering there can be seen at hot component in old pcb (TV). Just a thing to consider.
Offline nitro2k01
« Reply #17 on: July 19, 2012, 10:10:28 am »
Why is the video unlisted? Even the discussion originated here, I imagine the video can be interesting to "anyone".
Offline David_AVD
« Reply #18 on: July 19, 2012, 10:13:13 am »
It would be interesting to add fresh solder back to that track and see how much a heavy (manually added) solder coating affects the resistance.
Offline Bloch
« Reply #19 on: July 19, 2012, 10:14:27 am »
Yes the equation to calculate ohm is not as easy as with pure CU.
« Reply #20 on: July 19, 2012, 10:16:42 am »
Because I forgot to change it - I always set unlisted during upload to check it's OK and select the thumbnail image before publishing.
Offline dda
« Reply #21 on: July 19, 2012, 10:37:14 am »
Is the 'normal' track there going to struggle with 1A? I would have thought it would have done ok, what happens at higher current?
Offline dda
« Reply #22 on: July 19, 2012, 10:42:06 am »
I now also realise that my solder wick is shithouse. What brand do you use?
Online IanB
« Reply #23 on: July 19, 2012, 10:46:58 am »
Equally importantly, ask what iron he used  ;D
Offline David_AVD
« Reply #24 on: July 19, 2012, 10:51:28 am »
I use Chemwick brand and find it very good.  Some of the cheap ones are rubbish.  The bigger issue is usually people putting their fingers all over the braid.  This contaminates it and really reduces its effectiveness.
