Author Topic: Server Error Reports  (Read 947014 times)
0 Members and 15 Guests are viewing this topic.
Re: Server Error Reports
« Reply #25 on: October 12, 2017, 09:47:21 pm »
502, 22:47 BST
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #26 on: October 14, 2017, 11:00:17 pm »
Just now.
Seven Transistor Labs, LLC
Offline electricForce
« Reply #27 on: October 21, 2017, 11:33:34 pm »
Just now. Austin, TX
Offline suicidaleggroll
« Reply #28 on: October 23, 2017, 10:45:22 pm »
Couple of hours ago from Boulder, CO.  Couldn't get in for 5+ minutes (not sure how long exactly as I stepped away from the computer and just got back).
Offline ChrisLX200
« Reply #29 on: November 01, 2017, 10:21:32 pm »
Dammit - again just now (10:20pm), and it lost my carefully worded post :(
Offline sokoloff
« Reply #30 on: November 02, 2017, 09:54:17 pm »
~55 seconds ago, from Cambridge, MA. Multiple 50x errors attempting to access https://www.eevblog.com/forum/unreadreplies/ from both a cookied browser window and a new Incognito browser window.
Probably 15-20 seconds of outages/repeated failures, then it worked.
Was directed here, followed directions (or tried to), so posting.
Chrome Version 61.0.3163.100 (Official Build) (64-bit) on MacOS.
« Last Edit: November 02, 2017, 09:59:51 pm by sokoloff »
Offline kalel
« Reply #31 on: November 02, 2017, 10:05:14 pm »
Just a few min ago, Chrome.
Offline EEVblog
« Reply #32 on: November 02, 2017, 10:07:17 pm »
Don't think I've ever lost a post. I just hit the back button and the text is still there in the edit window.
Offline ChrisLX200
« Reply #33 on: November 02, 2017, 10:14:50 pm »
Quote from: EEVblog on Today at 09:07:17 AM>Quote from: ChrisLX200 on Yesterday at 09:21:32 AM
Nope, it wasn't. The back button took me to an empty editing window (well, actually a quote but my added text was missing).
Offline Richard Crowley
  • KJ7YLK
« Reply #34 on: November 02, 2017, 11:41:02 pm »
Yeah, that works sometimes.  It depends on when/where the error happens.
I have seen it happen both ways.  Although much more often on GearSlutz than here in EEVblog.
Their server (s?)are chronically slow. Sometimes so slow you wonder whether they are even "up".
Offline bitseeker
« Reply #35 on: November 04, 2017, 05:24:15 pm »
The link element for the forum's RSS feed (in the <head>) points to a URL that returns 403 Forbidden.
<link rel="alternate" type="application/rss+xml" title="EEVblog Electronics Community Forum - RSS" href="https://www.eevblog.com/forum/.xml/?type=rss" />
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #36 on: November 06, 2017, 03:43:26 am »
502 - Bad Gateway
At 14:25 AEDT or 03:25 GMT on 06/11/17 the forum main page dropped out and then returned to normal operation after about a minute or so with the assistance of the refresh button, as this interruption did not correspond with the scheduled regular backup time I thought it was worth a mention.
Offline hermit
« Reply #37 on: November 07, 2017, 10:03:07 pm »
I just got back in after a brief interruption.  Seems to happen once a day for the past few.  4:45 Eastern.
Offline gnifTopic starter
  • Views and opinions are my own
« Reply #38 on: November 10, 2017, 11:09:56 pm »
502 - Bad Gateway
I thought it wasn't even supposed to happen with a regular scheduled backup anymore.
Correct, there is still a very intermittent fault, each problem we fix exposes another one. I am seeing core dumps from PHP now, I just have not had the time to attach a debugger to one yet and see what is going on.
Offline kulla
« Reply #39 on: November 11, 2017, 02:53:56 pm »
You might as well try to enable slow log for php-fpm for requests that take lot of time and time out in the end, requests that need more than 10s and see what you get and why
« Reply #40 on: November 11, 2017, 03:27:05 pm »
It is enabled, we are not seeing slow requests anymore, its a backend crash.
The following users thanked this post: kulla
Offline SkrillBill
« Reply #41 on: November 20, 2017, 09:56:30 pm »
Error 502 just happened to me. Error instructed me to post in this thread. See attached.
Offline Mr. Scram
  • Display aficionado
« Reply #42 on: November 20, 2017, 10:10:31 pm »
I've experienced intermittent 502 server errors for the past few weeks, after they've been absent for a while. The most recent ones were just now, about 10-20 minutes ago. They tend to be on all pages, and typically last for about 1-3 minutes.
« Reply #43 on: November 20, 2017, 10:17:01 pm »
Thanks guys, I will see if I can trace down the cause. It's great there are getting fewer, it makes it easier to find the trigger in the logs :)
Offline Mr. Scram
« Reply #44 on: November 20, 2017, 10:28:56 pm »
Yes, I though you had the problem solved for a while. It's progress nonetheless :)
Offline SkrillBill
« Reply #45 on: November 21, 2017, 10:10:14 pm »
Recieved error 502 while browsing the open source hardware section of the forum. Stayed that way for 3-5 minutes. I tried going to the main website (eevblog.ocm) and was greeted by "Error establishing database connection".
Happened around 5:04pm Eastern
« Reply #46 on: November 21, 2017, 11:00:37 pm »
Thanks, that a new one.
Offline SkrillBill
« Reply #47 on: November 22, 2017, 10:05:17 pm »
Same thing happened again, 5:01pm eastern.
502 Error follows by "error establishing a database connection" on the main site.
Offline MK14
« Reply #48 on: November 22, 2017, 10:08:42 pm »
I also had error 502 (lasting for a few minutes) and "error establishing a database connection" on the main site.".
A few minutes ago. It is now 10:07 PM UK time.
At the start of the difficulties, the forum was failing to supply me with pictures. Then a minute or so later, I got the 502 errors. (Probably because I tried to reload the page, because of the missing pictures).
Offline Gyro
« Reply #49 on: November 22, 2017, 10:09:29 pm »
Error 524 Ray ID: 3c1f2717f9e435a8 • 2017-11-22 22:00:34 UTC
A timeout occurred
Followed by repeated 502 errors.
I seem to run into a block of 502 errors every day at some arbitrary time between 21.40 and 22.30 BST.
Best Regards, Chris
