Author Topic: Server Error Reports  (Read 970373 times)
0 Members and 42 Guests are viewing this topic.
Offline gnifTopic starter
  • Views and opinions are my own
Re: Server Error Reports
« Reply #850 on: May 04, 2026, 07:35:47 am »
edit: I conducted some tests in another place (to not spam here). Something insane is going on. I can send the characters I did send above, but then I can’t, then I can send them again.
Sounds a bit as if the two EEVBlog hosts do not have identical configuration?
They do, it's not possible for them to not be as they are maintained by puppet.
I am sorry everyone, my health has prevented me from getting back to this yet. I know it's frustrating, hopefully ill be able to investigate this in the coming few days.
Offline 2N3055
  • Country: hr
« Reply #851 on: May 04, 2026, 08:41:13 am »
Getting better should be your first priority...  :-+
Dr. Richard W. Hamming
The following users thanked this post: EEVblog, gnif
Offline squadchannel
  • Country: jp
  • deepl translate user
« Reply #852 on: May 04, 2026, 09:40:10 am »
Loading [MathJax]/extensions/Safe.js
am I only one who noticed that a small message pops up in the bottom-left corner of the browser when I refresh the page? :-//
Offline golden_labels
« Reply #853 on: May 04, 2026, 10:56:39 am »
Such a possibility is why I mentioned the exact IP address and certificate in another report.
But latter tests were done in a single, short session. I was interacting with only one IP address. This implies a single host unless anycast or a front load balancer is at play.
More so, I can now confirm it happens on both addresses.
My first report was for 192.154.109.3. Just now I tested it on 192.154.111.219. Problems appear on both.
In me it causes curiosity, not frustration.
Get better, take your time. I believe we can live with avoiding the @ character where it triggers the bug.
Why 📎 | We live in times when half of people have IQ below 100.
« Reply #854 on: May 04, 2026, 11:47:15 am »
This is because the LetsEncrypt SSL certificates are automatically generated and signed per host on a 15 day cycle. The certs do not get distributed by Puppet, but the config that generates them does. Because of various things that have occurred over the years (fire at the DC/replaced server, etc), they are simply no longer in sync for the refresh period, which doesn't really matter.
Load balancer, you will ping pong between servers no matter which IP you hit depending on server load.
As expected, the public have no control over which server handles the request, by design.
« Reply #855 on: May 04, 2026, 04:22:27 pm »
Earlier there was a question of reproducibility. It seems that this exact sequence is a sufficient condition to trigger the bug (but not a ncessary condition):
At-sign Pound Euro (separated by spaces).
Exact codepoints:  U+0040, U+00A3, U+20AC.
It may not be the minimal one, but should be enough for debugging.
Offline 44kgk1lkf6u
« Reply #857 on: June 06, 2026, 02:19:04 am »
I often get the "you are banned from using this forum" message after the CrowdSec check passes.  Is it necessary to have both?
« Reply #858 on: June 06, 2026, 02:42:27 am »
Crowdsec is absolutely required, the ban however seems to be something different. Please DM me a screenshot and your IP and I will investigate the ban itself.
In future please do not though reply to this thread unless there is actually a server error.
Online jc101
« Reply #859 on: August 07, 2026, 03:48:30 pm »
Not the forum, but the main EEVBlog website.
If you go to www.eevblog.com you get an NGINX 502 bad gateway error. Drop the www at the front and all is good, bar a huge list of cookies to untick that wasn't there the last time.
The following users thanked this post: antenna
« Reply #860 on: August 08, 2026, 04:55:31 am »
The cookies are ad related, dave has been making some changes.
The 502 I can't reproduce, both http servers are reporting they are healthy.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #861 on: September 10, 2026, 01:21:54 am »
Page loading is extremely slow and also multiple Bad Gateway error messages displayed, as described by other members in the newly created thread linked below. Also, an unusually high number of "guests" on the forum is also noted.  :-BROKE
https://www.eevblog.com/forum/news/getting-a-lot-of-502-bad-gateway-errors/
The following users thanked this post: tautech, antenna
Offline EEVblog
« Reply #862 on: September 10, 2026, 04:14:36 am »
Yes, they absolutely dominate by orders of magnitude.
« Reply #863 on: September 10, 2026, 06:52:45 am »
I don’t know the details of this setup, but perhaps the reverse proxy could distribute traffic based on the Cookie header? Bots are unlikely to send a string “EEVblogForum=” in it, while I believe that all logged in users will. This way guest (and bot) traffic may go to a smaller subset of backend nodes, while everything else gets a relatively smooth ride.
Using string “PHPSESSID=” instead may work too, but I guess agentic LLMs nowadays will simulate that part pretty well. But if the offending guests are not sending it, it’s one more way to send them to tarpit without affecting normal users beyond the first request.
« Reply #864 on: September 10, 2026, 07:42:09 am »
We already properly load balance without resorting to pinning via cookies or IP due to proper sync between servers. The problem we we are literally overloaded with requests and I am having to trawl through millions of them to determine ways to detect the sources and force them through a captcha on mass.
The following users thanked this post: EEVblog, Dr_Bob
Offline Psi
« Reply #865 on: September 10, 2026, 08:12:52 am »
Trick the AI into giving away that it's an AI by having a button that is white on white and invisible to everyone else but looks like something the AI will always need to click as part of its web trawling process.
« Last Edit: September 10, 2026, 08:17:52 am by Psi »
The following users thanked this post: m100
« Reply #866 on: September 10, 2026, 08:18:37 am »
We already have such measures, they simply do not work anymore
Offline EEVblog
« Reply #867 on: September 10, 2026, 08:40:22 am »
At this point I'm starting to think that this is being done deliberately so that we take down the Baidu thread...
« Reply #868 on: September 10, 2026, 08:53:15 am »
Perhaps, but while they are hammering it I can use the metrics to identify their networks and blacklist them.
Offline Psi
« Reply #869 on: September 10, 2026, 08:54:53 am »
If it's all users without a login then probably no need to delete anything, just limit some pages/threads to only users who are logged in.
hehe, limit the entire forum to logged in users only except for the cooking page.  :-DD
« Reply #870 on: September 10, 2026, 08:59:54 am »
Seems I have won, server load is returning to normal and logs show no 502 errors anymore.
Edit: spoke too soon, still seeing some but not as bad as earlier
The following users thanked this post: golden_labels
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #871 on: September 10, 2026, 09:32:26 am »
Happening to me this morning. When I first logged on I saw 170k guests now inching up to 200k ... error popping up every 3 or 4 page refreshes.
Offline coromonadalix
« Reply #872 on: September 10, 2026, 09:39:59 am »
241244 Guests, 133 Users (1 Hidden)
slow connection(s)   Bad Gateway etc ...
« Reply #873 on: September 10, 2026, 09:49:43 am »
Please stop reporting what I am clearly already working on
The following users thanked this post: EEVblog, Zucca, Brumby, 2N3055, eutectique
Offline wilfred
« Reply #874 on: September 10, 2026, 01:35:26 pm »
FYI. It is "en masse". French for all together.
And I just got a 502 error.
The following users thanked this post: gnif
