Author Topic: What ICs are used in this rocket?  (Read 1742 times)
Offline FaringdonTopic starter
« on: May 03, 2024, 07:14:06 pm »
The space rocket that just launched to the moon...
https://youtu.be/y2AslDDnk0E
What ICs are used on this for processors?  Atmel? Or they use FPGA only?
Also, what Power Supply control ICs are used?, eg, Analog.com , or they use vicorpower  modules?
'Perfection' is the enemy of 'perfectly satisfactory'
Offline Gyro
Re: What ICs are used in this rocket?
« Reply #1 on: May 03, 2024, 07:30:42 pm »
You seriously expect anyone here to know what make of ICs or power modules are used in a Chinese Lunar probe?  ::)
Troll.
Edit: Preserved OP original post.
« Last Edit: May 03, 2024, 07:46:28 pm by Gyro »
Best Regards, Chris
The following users thanked this post: Sal Ammoniac, nctnico, Warhawk, tooki, Faringdon
Online coppercone2
« Reply #2 on: May 03, 2024, 08:09:06 pm »
this one is a little light on the effort put in by topic starter
there is like, a billion different space electronics solutions that are usable in space, depending on requirement. its probobly as cheap as possible, because its not a military satellite
so you want someone to write an entire time line of how electronics changed since the apollo missions.......
https://semiconductors.teledyne-e2v.com/en/products/space-grade-solutions/space-grade-processors-modules-memories/
https://www.frontgrade.com/products/space-grade-fpgas
https://ntrs.nasa.gov/api/citations/20080015740/downloads/20080015740.pdf
https://www.analog.com/en/signals/thought-leadership/challenges-for-electronic-circuits-in-space-applications.html
there that should answer your questions
« Last Edit: May 03, 2024, 08:13:45 pm by coppercone2 »
The following users thanked this post: Faringdon
Offline Kim Christensen
« Reply #3 on: May 03, 2024, 08:30:29 pm »
They use space age technology.   ::)
Offline tggzzz
« Reply #4 on: May 03, 2024, 08:53:27 pm »
Regrettably, it is typical of the effort.
Online SiliconWizard
« Reply #5 on: May 03, 2024, 09:24:45 pm »
I think the OP is trying to get into the space industry, and of course trying to figure out why China is gonna win this industry as well as with power supplies. :-+
The following users thanked this post: tooki, Faringdon
Offline Bud
« Reply #6 on: May 03, 2024, 09:45:22 pm »
Watch CuriousMarc channel, they often post on (at least vintage) space electronics teardowns and repair.
Offline tom66
« Reply #7 on: May 03, 2024, 09:51:06 pm »
For anyone who is curious as to the answer rather than just with Faringdon being a troll  :).
Radiation-hardened FPGAs and microcontrollers/SoCs most likely if they are "old space".
Or they could be using consumer devices with higher tolerance to single event upsets which is the SpaceX ("new space") approach - reasonably normal computers (they use x86 Intel processors of one kind or another) but with much redundancy and self-checking. See here:  https://space.stackexchange.com/questions/9243/what-computer-and-software-is-used-by-the-falcon-9
Offline EPAIII
« Reply #8 on: May 04, 2024, 10:43:58 am »
And aircraft aluminum. Billet only, of course.
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
Offline soldar
« Reply #9 on: May 04, 2024, 11:15:12 am »
It's all noodle logic.
Offline coppice
« Reply #10 on: May 04, 2024, 11:26:07 am »
That thread seems to imply that radiation hardened ICs and large scale redundancy are alternatives, but that's not really true. The two have usually been combined to achieve acceptable results.
Offline pcprogrammer
« Reply #11 on: May 04, 2024, 11:27:53 am »
So everything digital from Italy uses spaghetti logic  :-//
And the USA has burger logic  >:D
Offline coppice
« Reply #12 on: May 04, 2024, 11:31:41 am »
and all the best noodles are now made in Taiwan.  :)
Offline Gyro
« Reply #13 on: May 04, 2024, 12:15:11 pm »
The OP already has a thread on hardened semiconductors, discrete vs IC etc... https://www.eevblog.com/forum/renewable-energy/discrete-smps-have-any-advantages/
Quite why he wants to know the manufacturers of the silicon in this particular rocket is beyond me. Ed: Whether they use Vicor power modules, even more so.
« Last Edit: May 04, 2024, 12:28:42 pm by Gyro »
Best Regards, Chris
« Reply #14 on: May 04, 2024, 02:49:59 pm »
Sometimes it also uses structural noodles, but payload and deltaV suffers...
Offline tggzzz
« Reply #15 on: May 04, 2024, 03:44:30 pm »
The second question would be preparation for a crusade against Chinese/foreign/whatever PSU manufacturers.
A cynic might think it is just a troll, or so that he has yet another post to (uncritically) thank. The word "egoboo" springs to mind, albeit a rather twisted variant.
« Reply #16 on: May 04, 2024, 03:54:45 pm »
Thanks, most of the Chinese Power Supplies ive worked on, had  chips like UCC38C43 or Fairchild chips in them.
The only Chinese  ICs  i saw were the ON/OFF controlled type offline flyback  ones.
Or do the Chinese have their own speciality  power supply control ICs?,  but they don't make them sellable to the world outside of China?
Offline floobydust
« Reply #17 on: May 04, 2024, 05:22:41 pm »
Considering OP's "friend" was apparently illegally selling semiconductors to the commies - and now he's asking what semi's are going into commie rockets?
We're being trolled yet again  |O  I have to conclude he's working for 'em.
Now you're asking us again about stuff the commies have? All your "schematics" use Linear Tech parts - the most expensive in the business.
Did you finish your drone-making startup? Hint: china makes all the major components - rare-earth PM motors, cameras, batteries etc.
Plan your next trip to Shenzhen already.
Offline Gyro
« Reply #18 on: May 04, 2024, 05:49:54 pm »
Presumably they don't use the "offline flyback ones" because they don't have a long enough mains lead. They clearly lack your design skills, you should offer your services.
Best Regards, Chris
The following users thanked this post: tom66, Faringdon
Offline Coordonnée_chromatique
« Reply #19 on: May 04, 2024, 06:14:32 pm »
Offline tom66
« Reply #20 on: May 04, 2024, 10:51:37 pm »
Right, but the approach SpaceX take is to tolerate SEUs in the downstream computers and correct them at the engine/controller level with much cheaper hardware which can be adequately radiation hardened without increasing the cost of the avionics too much.
Whereas the approach for "old space" might be to use rad-hard hardware everywhere and design for minimum fault occurrence.  See for instance the Space Shuttle computers, which were quintuple redundant (two could be lost with mission still OK to proceed; three with normal landing parameters; and four with a safe landing still possible) but these were also radiation-tolerant systems with much slower, older process geometry.  Practically everything on the craft will have been rad-hardened because "that's just how you do it".
Offline 5U4GB
« Reply #21 on: May 05, 2024, 08:37:45 am »
Not aluminium, Chinesium.  At first glance it looks exactly like aluminium and is priced as such, but then once the return window has closed you find out it doesn't conduct electricity and dissolves in seawater.
« Reply #22 on: May 05, 2024, 10:27:55 am »
Thanks, so do the Chinese have these kind of speciality  power supply control chips like the Analog.com ones, and the ti.com ones etc etc?
..but they just dont sell them to the rest of the world?
..or..So you are saying they only make the "big stuff"?, like the motors etc?
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #23 on: May 05, 2024, 10:52:54 am »
They do - plenty of PSU ICs available on LCSC, they're just harder to find due to LCSC's poor parametric search and the datasheets being in Chinese.
Day Job: Mostly LEDs
Offline 5U4GB
« Reply #24 on: May 05, 2024, 11:04:20 am »
You can also see this in action sometimes when disassembling different generations of Chinese-made electronics, older versions will have recognisable parts in them, then they'll start sprouting vaguely-similar Chinese equivalents with minimal info available, and finally completely alien parts with no info available.  It's a bit like the SF movie/story Screamers / Second Variety which starts out with known devices and then over time they become more and more alien.
