What really disappoints me is in the UK we are still building homes without heatpumps. Gas boilers and gas networks continue to be installed.
I should darn well think so, given electric heat pumps are more expensive to run, than gas boilers. If the government really want people to have heat pumps, they need to make electricity much cheaper, think nuclear, then people will be queuing up to get one.
Not sure that they are more expensive to run. Basic maths assuming Ofgem capped rates.
Gas = 7p/kWh
Electric = 29p/kWh
Gas boiler efficiency (net) = ~85% under normal conditions. 90% best case but rarely achieved.
Heat pump efficiency (net) = ~350% seasonal average.
So per kWh of heat, the gas boiler costs 8.2p whereas the heat pump costs ... 8.3p.
There may be some variation either side of these figures but in the UK alone, a heat pump should cost *about as much* as a gas boiler to run.
Going on agile tariffs, like Octopus Tracker, may show more of a difference. Today's tracker costs are 3.69p/kWh for gas and 16.9p/kWh for electricity. Giving per kWh equivalents of 4.34p/kWh and 4.82p/kWh. But still, a pretty close parity, and the heat pump could easily win if the SCOP was better, whereas the gas boiler is already pretty much as efficient as it gets.
The problem is that heat pumps cost so much more to install, so it doesn't really matter even if they cost, say, 2p less per kWh, the TCO doesn't add up if you assume 10 year lifespan before major refurbishment is required. The cost per kWh of heat needs to be half or less to make them pay off and even then, it's arguable as to how cost effective they are. And replacing a gas boiler costs ca. £2,000 whereas a heat pump costs at least £5,000 but possibly double that in the worst case.
Really, heat pumps need to fall in price, that will make them a lot more affordable. I don't personally understand why they cost so much, but I haven't looked in depth at one.
