Author Topic: Whats your Work-Bench/lab look like? Post some pictures of your Lab.  (Read 2926987 times)
Offline AF6LJ
Re: Whats your Work-Bench/lab look like? Post some pictures of your Lab.
« Reply #3525 on: March 23, 2018, 04:32:39 pm »
I thought the forum was fine without all the PIMK however...........
I do want the HP-3478 Hello Kitty edition to go with my Hakko Hello Kitty edition.....
(The one I don't have yet). :P
Sue AF6LJ
Offline tautech
« Reply #3526 on: March 23, 2018, 05:58:29 pm »
Finished setting up my hide-away mini-bench at home, so that I can work on interesting stuff.
Doesn't that SDG1062X have the wrong label on it ?  ;)
Offline BillB
« Reply #3527 on: March 23, 2018, 06:12:52 pm »
Why yes, yes it does.   :)
I wish everything else was mislabeled.
The following users thanked this post: tautech, hwj-d
Offline Elasia
« Reply #3528 on: March 23, 2018, 06:33:58 pm »
Nice setup!  Thats close to what im building.. just not a siglent dmm, how well do you like yours?  I got the arb and a ps but still waiting in line for their new 4 channel scope
The following users thanked this post: BillB
Offline tautech
« Reply #3529 on: March 23, 2018, 06:38:58 pm »
There's only so much you can do of course and for the SDM you can't magically turn a 3055 into a 3065X, the have different internals.
Offline BillB
« Reply #3530 on: March 23, 2018, 06:57:25 pm »
I like it.  I think Siglent offers good price/performance.  The features and user interfaces on the devices are fine for me, the accompanying PC connectivity applications (their EasyTools suite) are just ok.  I'm an OCD matchy-matchy type, so having an equipment suite from a consistent brand is important to me.  However, if I were to do it over again, for the minimal difference in cost I might have stepped up to the SDM3055 from the SDM3045X (not that I need anything the 55 offers over the 45 - I struggled to justify it to myself somehow, but failed).
Understood.  The same is true with the SDS1104X -> SDS1204X.  Plus, that was a bigger price swing that even the 45->55 I just couldn't justify.  :)
Offline tautech
« Reply #3531 on: March 23, 2018, 07:12:59 pm »
Not AFAIK. Same HW, SW limited.  ;)
Offline BillB
« Reply #3532 on: March 23, 2018, 07:35:48 pm »
Oh, really?  I thought the front ends were different?
Offline tautech
« Reply #3533 on: March 23, 2018, 07:43:01 pm »
I invite you to dig out Dave's teardown of SDS1202X-E (#985) and watch for clues.
Offline Edison
  • Country: cz
« Reply #3534 on: March 23, 2018, 09:45:06 pm »
We have the same source Siglent (My X - is your X-E, or the wrong one eye can see)
how satisfied are you with him?
I just communicate with a representative of the manufacturer error in the software. data communication, otherwise I am very satisfied.
« Last Edit: March 23, 2018, 09:56:17 pm by Edison »
Everything works as the weakest link in the chain
Offline Elasia
« Reply #3535 on: March 23, 2018, 10:06:57 pm »
Dont forget 1042 ;)
I might investigate its fw if i have time... but looks like a few others already actively decode their files for the scopes and gens
One im interested in is if SPD3303X = SPD3303X-E, that might be fun to do
Offline Edison
  • Country: cz
« Reply #3536 on: March 23, 2018, 10:26:00 pm »
X is not equal X-E
X - ethernet + USB comunication, set point 1mV/1mA
X-E (economy) - USB comunication, set point 10mV/10mA
Offline Elasia
« Reply #3537 on: March 23, 2018, 10:42:16 pm »
X is not equal X-E
My -E has a usb... the sw mod would be 10/10 to 1/1 if its the same guts, not that most would even bother when considering the minimal difference but i like tearing into other peoples fw/sw
http://www.siglentamerica.com/wp-content/uploads/dlm_uploads/2017/10/SPD3303X_DataSheet_DS0503X-E01A.pdf
Offline Edison
  • Country: cz
« Reply #3538 on: March 23, 2018, 11:00:25 pm »
Excuse X-E has an Ethernet difference in display -1digit. My Rigol does not have an Ethernet economy.
« Last Edit: March 23, 2018, 11:03:17 pm by Edison »
Offline Elasia
« Reply #3539 on: March 23, 2018, 11:11:52 pm »
Right but its still just a TFT, so the question becomes can the SPD3303X code be modded to run a SPD3303X-E? And that gets to the fun bits
OR  is it an identical codebase with just a bitflip?   but that would make it a boring mod :p
Offline tautech
« Reply #3540 on: March 23, 2018, 11:12:55 pm »
Then you might want to look here:
https://www.eevblog.com/forum/testgear/siglent-ads-firmware-file-format/
Offline BillB
« Reply #3541 on: March 23, 2018, 11:38:16 pm »
I do remember viewing both of Dave's teardowns for the 1104 and 1204, and went back and re-watched them.  I don't know why I was thinking they were different front ends.  Old age, I guess.  I haven't seen much chatter yet about a successful "upgrade" of the 1104.
It's probably like the other devices where the codebase is the same, but there are one or more XML configuration files that determine the feature set.  Once you get root access through the console, it's straightforward.  The problem is, hacking the root password for the image is difficult and requires linux system image reverse engineering skills and plenty of time.
The following users thanked this post: Elasia
Offline Elasia
« Reply #3542 on: March 23, 2018, 11:41:47 pm »
Winner Winner Chicken Dinner ;)
Edit: I'd speculate its just because the scope model is newer to market and is just a matter of time... plus with an only difference of 100Mhz to 200Mhz and really even then you end up pushing its front end.. but still a decent sample rate if using it in two channel mode and 2/4 are shut off it looked like.  Less of an attractor of some nutter like myself.. where as you take a Rigol... that thing has incentives written all over it.
« Last Edit: March 23, 2018, 11:46:16 pm by Elasia »
Offline Edison
  • Country: cz
« Reply #3543 on: March 24, 2018, 12:40:28 am »
Somehow we escaped from topic  :scared:
« Last Edit: March 24, 2018, 12:45:05 am by Edison »
Offline JustSquareEnough
« Reply #3544 on: March 24, 2018, 01:45:21 pm »
@Edison, really cool setup. I like the side keyboard pull out idea!
The following users thanked this post: Edison
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #3545 on: March 24, 2018, 02:07:32 pm »
Welcome to the EEVBlog!  :-DD
Again nice setup!
Offline Edison
  • Country: cz
« Reply #3546 on: March 24, 2018, 03:05:50 pm »
At the place where the keyboard is usually - above the knees - I have an illuminating board for drawing circuit boards. is currently not fitted, is in the garage and is waiting for some modifications.
After completing nafotíme and show.
thank you for the compliment
Offline Edison
  • Country: cz
« Reply #3547 on: March 24, 2018, 03:17:18 pm »
It is likely to be in all forums.
I also thank you for praise, i have a lot of photos,  gradually insert
Offline Edison
  • Country: cz
« Reply #3548 on: March 30, 2018, 12:49:24 am »
Rigol  "Hello kitty" supplement  :-DD
Offline Edison
  • Country: cz
« Reply #3549 on: March 30, 2018, 12:52:54 am »
Yeah my container  :-DD
