Well with standard, 1 sided ring-pad perf-board, and 1206 parts, I used my strong flux, and it got under the parts ,and there's a bit of DC leakage messing with the biasing. I used steel wool on the perfboard 1st, so I should have used my safer flux. Without extra flux the wetting takes too long, and doesn't spread the solder near as good.
And 1206 was a little over sized. So I just made an 0805 amplifier circuit, and those fit much nicer between the ring pads, without overlapping.
But what I did 1st this time, was tin a pile of pads, but that filled them all in, so I had to go back with solder wick to remove most of it. Then to get nice clean bonds, I tinned all the parts too. Then I just had to lay them in place and tack 1 side at a time, and check resistances before adding caps.
But yeah I'm quite happy with that. All my SMD parts are cheap ebay/amazon ones, and they are all way closer to their ratings. And have lower parasitic's too, are and cheaper.
I have lots of breakout boards for chips or transistors if needed. I have some Dremel accessories that might make cutting up copper clad boards easier, but I haven't tried any of them yet.
