Author Topic: Windows 10 calculator bug?  (Read 9695 times)
Offline splinTopic starter
« on: August 01, 2018, 11:19:26 pm »
My Win 10 caclulator has just started misbehaving - not sure if it has been updated or something odd is happening to my PC.
In scientific mode, if I click 10^x on the result of some other operations it gives 'Invalid input'.
Eg: Enter 100, click log gives 2 as expected. Now clicking 10^x gives 'Invaild input'. Same if it follows a sqrt(), sin(), ln(), e^x etc but ok after 1/x and entering a number.
Is this just my computer?
Offline ataradov
    • Personal site
Re: Windows 10 calculator bug?
« Reply #1 on: August 01, 2018, 11:31:51 pm »
I get the same result.
Alex
« Reply #2 on: August 01, 2018, 11:39:16 pm »
Ah ha!
Oh Microsifty, Sifty, Sifty... (said using your best Rimmer impersonation)
Offline Nusa
« Reply #3 on: August 01, 2018, 11:43:35 pm »
Your example works on my Windows 7 calculator.
« Reply #4 on: August 01, 2018, 11:52:22 pm »
Casio FX-991EX FTW.  Remains working after windows updates ;)
The following users thanked this post: coldfiremc
Offline james_s
« Reply #5 on: August 01, 2018, 11:55:57 pm »
The calculator that comes with Win10 is a bad joke. The Win7 calculator is ok, but the one from XP or Vista is better. I have the Vista calculator on my Win7 machines.
Offline bitseeker
« Reply #6 on: August 01, 2018, 11:58:08 pm »
Looking at what the "calculator" displays as its supposed calculation for the sequence, 10^(log(100)), it should give the correct answer, since it even puts in the parentheses to operate on the log first.
Microsoft "calculator." Does not compute.
It's form over function. Yet, the form isn't that great. So...
« Reply #7 on: August 02, 2018, 12:04:53 am »
But I'm pretty sure this was working a day or two ago at the most as it is something I do quite often, but the latest windows update was (apparently) on the 10th - three weeks ago.
Offline CatalinaWOW
« Reply #8 on: August 02, 2018, 12:37:31 am »
Playing around with this a bit shows some interesting behavioral characteristics.  The problem is preserved through storage in memory and simple arithmetic operations (Take the log and multiply by 2. Works.  Then antilog shows same failure).  And doing a few switches in mode and then recalling the answer shows a clue to the source of the problem.  The answer has is correct for 24 digits and then shows some rounding error.
Just more evidence for two things we already knew about.  First, in spite of huge sums spent on QA, MS has fairly frequent fails.  And second, the scientific market doesn't get the attention that the larger parts of their customer base receives.
This kind of behavior matters to me even though the MS calculator is not my first, second or third choice for such calculations.  I fairly frequently end up someplace where my preferred options are not available, and MS calculator is almost always to be found.
Offline amyk
« Reply #9 on: August 02, 2018, 12:47:19 am »
I recommend Microsoft Calculator Plus: http://web.archive.org/web/20120427223659/http://download.microsoft.com/download/0/4/5/045ae76d-2edb-4e6b-84af-aba399e2f2e8/CalcPlus.msi
(Archive link because the b*stards decided to remove this very useful and far more functional piece of software from their download site.)
« Reply #10 on: August 02, 2018, 01:08:19 am »
Bugs happen in software - I'm sure it will be fixed soon enough. But what puzzles me is that  is that I felt certain that I didn't have this problem even yesterday as I have been doing a number of dB to ratio type calculations lately and I'm sure I would have run into this bug lots of times.
All the calc.exe apps under C:Windows are dated 12th April 2018 so perhaps the bug has been around much longer than I expected. Unless... <Paranoia Alert!>... Microsoft has sneaked in some undeclared update...
Offline bitseeker
« Reply #11 on: August 02, 2018, 01:35:13 am »
Time to get some fresh batteries for my HP calculator. :-DD
Offline edpalmer42
« Reply #12 on: August 02, 2018, 01:58:28 am »
I just checked mine.  It has the same error.
File version:  10.1805.1804.30001
Date Modified:  5/25/2018 5:26 PM
Ed
Offline bitseeker
« Reply #13 on: August 02, 2018, 02:46:39 am »
Still broken in Calculator 10.1806.1821.0
Offline james_s
« Reply #14 on: August 02, 2018, 03:24:26 am »
They don't spend huge sums on QA anymore, they fired all the QA staff years ago. Nadella was quoted as saying "Who better to test the code than the developers who wrote it."  Today they rely heavily on automation and customers reporting bugs. The "Insiders" are in effect unpaid QA testers.
Well, here we see the result.
Offline GigaJoe
« Reply #15 on: August 02, 2018, 03:30:48 am »
calc Version 10.1712.10601.0
OS Ver : 1803.17134.165
can not reproduce any errors ...
Offline bitseeker
« Reply #16 on: August 02, 2018, 04:23:27 am »
 :palm:
Offline maukka
« Reply #17 on: August 02, 2018, 05:23:51 am »
Never got used to the new calculator. Here's a perfect replacement:
https://winaero.com/blog/get-calculator-from-windows-8-and-windows-7-in-windows-10/
Offline JPortici
« Reply #18 on: August 02, 2018, 06:02:30 am »
works for me, but i'm stuck with 1703. did they even break the calculator with updates?
(Version 10.1706.1862.0)
Offline bitseeker
« Reply #19 on: August 02, 2018, 06:04:36 am »
Yes, they did. Welcome to Windows 10, where you never know what you're gonna get.
Offline PlainName
« Reply #20 on: August 02, 2018, 06:08:01 am »
If you want to do calculator-type stuff, as opposed to playing with a simulated calculator, I can thoroughly recommend OpalCalc.
Offline Gixy
« Reply #21 on: August 02, 2018, 06:18:08 am »
I personnaly recommend HP15C emulator. RPN nostalgy…
(same problem here with calc on W10)
Offline bitseeker
« Reply #22 on: August 02, 2018, 06:20:10 am »
RPN FTW!
Offline Deridex
  • IMHO
« Reply #23 on: August 03, 2018, 09:27:45 pm »
I tend to use Microsoft Mathematics for any serios calculations if i don't have a calculator at the hand.
I think it's free since a few years.
Offline malagas_on_fire
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #24 on: August 03, 2018, 09:43:31 pm »
 Im still faithfull to a real calculator as possible but software calculators should not be presented has a problem. Report to microsoft and install galculator its open source and uset to run on nokia n800 mini tablet
If one can make knowledge flow than it will go from negative to positve , for real
