Author Topic: wtf is this weird component? solved, thermistor.  (Read 1803 times)
Offline coppercone2Topic starter
  • √Y√... 📎
« on: March 07, 2021, 06:40:09 am »
I am trying to fix something (DSA) and it has this inside of it. I cannot recognize it.
It does not look like a battery that I know of
I cannot find the designator for it, the batteries are BT. this does not seem to have a BT nearby
Looks a little like a coin cell but not really.
« Last Edit: March 07, 2021, 07:57:38 am by coppercone2 »
Offline Alex Eisenhut
  • Place text here.
Re: wtf is this weird component?
« Reply #1 on: March 07, 2021, 06:43:26 am »
A tortured piezo buzzer maybe?
  • √Y√... 📎
« Reply #2 on: March 07, 2021, 06:44:48 am »
hmm. it reminds me of a MOV for some reason but its position makes no sense
  • √Y√... 📎
« Reply #3 on: March 07, 2021, 06:46:07 am »
the in circuit resistance is 8 ohms.
so that does sound like an audio thing ?
why is it trashed, the rest of the circuit is pristine, save for some crusty dip sockets
« Last Edit: March 07, 2021, 06:48:06 am by coppercone2 »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: March 07, 2021, 07:00:47 am »
What's it wired to, AC power maybe?  Could be an NTC.  8 ohms might be healthy.  See if it drops when heated.
Haven't seen an uncoated one since... vintage TV sets maybe, I think?  Or maybe that all burned off somehow, yeech.
Seven Transistor Labs, LLC
Offline I wanted a rude username
  • ... but this username is also acceptable.
« Reply #5 on: March 07, 2021, 07:09:32 am »
Silver-plated copper sometimes corrodes weirdly, and without needing an electrolyte ... may be triggered by sulfur outgassing from plastics.
  • √Y√... 📎
« Reply #6 on: March 07, 2021, 07:42:01 am »
it only has DC power input from a regulated supply
the power draw is ~400mA to a linear regulator. I will try to trace the circuit before heating it
Offline t0m
« Reply #7 on: March 07, 2021, 07:42:30 am »
VL2020 maybe
  • √Y√... 📎
« Reply #8 on: March 07, 2021, 07:43:59 am »
no, it does not have the typical coin cell profile I don't think, and it reads real close to 8ohms, not a coincidence I think.
It looks nothing like the picture of a VL2020
The outline for it looks like a rectangle also, it does not match the pcb silk screen (it is small in comparison, so its overloading the artwork). It looks like 2 things set in a ring, not like a crimped coin cell, the outer radius is very geometrically nice, looks like it was taken out of a mold or something. The other cell in this thing is a renesas fully encapsulated one in a orange plastic box with a bunch of epoxy, it makes no sense that the designers would go crazy for 1 coin cell but not the other one in terms of safety/reliability (the other one is swiss made!). And it already has a 3Vaa battery and a coin cell, i don't think it would have 2 coin cells. 3 batteries on 1 pcb?? It is also across the entire PCB from the voltage input.
the dimensions are 3.5mm by 16 mm measured with a machinists rule
« Last Edit: March 07, 2021, 07:49:40 am by coppercone2 »
  • √Y√... 📎
« Reply #9 on: March 07, 2021, 07:51:10 am »
I decided to pull it off the PCB double sided tape because it looks like a huge piece of shit anyway, the designation underneath is TH1. The batteries are designated BTx
So thermistor 1 makes sense? This unit was powered by NICAD batteries.
« Last Edit: March 07, 2021, 07:53:08 am by coppercone2 »
  • √Y√... 📎
« Reply #10 on: March 07, 2021, 07:56:05 am »
i put a little bit of solder on top, it dropped to 7 ohms, so it is maybe a NTC
any ideas on a part number? Do you think this thing is fine?
The problem I am troubleshooting is intermittent turn off, I thought it was crashing because both batteries are totally dead, so I thought to replace those first.
Not sure what a peizo buzzer does when measured, but I thought they would be high impedance, so if its 8 ohms, with a 10% chance in resistance from a little bit of heat, it is the main contributing circuit element to the low resistance  in the circuit I think. I am a little scared of desoldering it because of how it looks. It fits the description of a RTC device without a coating.
I guess it used to look nice and something took it out. When I replace the batteries I will measure it with the device turned on to see if its contributing
It powers off after it is turned on for a little bit, I am not exactly it is correlated to on time , but when it turns off, you do need to wait a little bit before it can turn back on, but I thought it was something to do with a dead battery and charge draining or whatever. The amount of time it has before it turns off is a little random.
« Last Edit: March 07, 2021, 08:01:35 am by coppercone2 »
